How to put a specific part to Lock Items on/off in Bill of materials using Ilogic
manu.marjanen
manu.marjanen
How to put a specific part to Lock items on/off in Bill of materials using Ilogic?
For example,  if Iproperties custom fields says "Locked" then those specified parts Lock Items go ON in Bill of materials.
And the other way, if Iproperties custom fields says "UnLocked" then those a specified parts Lock Items go OFF in Bill of materials.
JelteDeJong
This example will lock the item in the first row
Dim doc As AssemblyDocument = ThisDoc.Document
Dim def As AssemblyComponentDefinition = doc.ComponentDefinition
Dim bom As BOM = def.BOM
bom.StructuredViewEnabled = True
Dim bomView As BOMView = bom.BOMViews.Item("Structured")
Dim firstBomRow As BOMRow = bomView.BOMRows.Item(1)
Logger.Info("Lock item with number: " + firstBomRow.ItemNumber)
firstBomRow.ItemNumberLocked = True
Jelte de Jong
Blog: hjalte.nl - github.com
manu.marjanen
Thanks for your quick answer.
Now the code is locking the first row, but can you edit the code so that it is locking part names individually (Part:1)?
JelteDeJong
something like this:
' set name of occurence here
Dim name As String = "Part:1"
Dim rows = bomView.BOMRows.Cast(Of BOMRow)
Dim row = rows.Where(Function(r)
                         Dim occs = r.ComponentOccurrences.Cast(Of ComponentOccurrence)
                         Dim occ = occs.Where(Function(o) o.Name.Equals(name)).FirstOrDefault()
                         Return (occ IsNot Nothing)
                     End Function ).FirstOrDefault()
Logger.Info("Lock item with number: " + row.ItemNumber)
row.ItemNumberLocked = True
Jelte de Jong
manu.marjanen
Yes, this is just what i needed. Thanks a lot 😀
