How to pick a folder in vba
I'm trying to open a folder dialog box to pick a folder in vba.
I've tried with "msofiledialogfolderpicker" and also with "FolderBrowserDialog" but it doesn't work because I think they are not Inventor class.
Could you please help me ?
Thank you
Mathias
Lewis.Young
The below code will open a folder dialog box:
SyntaxEditor Code Snippet
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
     'Function purpose:  To Browser for a user selected folder.
     'If the "OpenAt" path is provided, open the browser at that directory
     'NOTE:  If invalid, it will open at the Desktop level
    Dim ShellApp As Object
     'Create a file browser window at the default folder
    Set ShellApp = CreateObject("Shell.Application"). _
    BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
     'Set the folder to that selected.  (On error in case cancelled)
    On Error Resume Next
    BrowseForFolder = ShellApp.self.Path
    On Error Goto 0
     'Destroy the Shell Application
    Set ShellApp = Nothing
     'Check for invalid or non-entries and send to the Invalid error
     'handler if found
     'Valid selections can begin L: (where L is a letter) or
     '\\ (as in \\servername\sharename.  All others are invalid
    Select Case Mid(BrowseForFolder, 2, 1)
    Case Is = ":"
        If Left(BrowseForFolder, 1) = ":" Then Goto Invalid
    Case Is = "\"
        If Not Left(BrowseForFolder, 1) = "\" Then Goto Invalid
    Case Else
        Goto Invalid
    End Select
    Exit Function
Invalid:
     'If it was determined that the selection was invalid, set to False
    BrowseForFolder = False
End Function
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Thanks a lot Lewis, it works very good.
I wasn't good enough in VBA to think about shell.
