How to pass the transformation matrix to imported component inside part environment using c#
sneha.sadaphal
sneha.sadaphal
I am loading the step file as a imported component in part environment by using c# API
But I want to rotate the part from Y up to Z up direction (Mentioned in attached images)
Can anybody have the solution for this?
here is the code snap for above
 PartDocument pDoc = _pDoc as PartDocument;
                PartComponentDefinition oPartCompDef = pDoc.ComponentDefinition;
                ImportedGenericComponentDefinition impPart = (ImportedGenericComponentDefinition)oPartCompDef.ReferenceComponents.ImportedComponents.CreateDefinition(stepdownload);
                impPart.ReferenceModel = true;
                impPart.IncludeAll();
                oPartCompDef.ReferenceComponents.ImportedComponents.Add((ImportedComponentDefinition)impPart);
Michael.Navara
You can use MoveFeature after import or add this imported component to the assembly with appropriate orientation.
Dim part As PartDocument = ThisDoc.Document
Dim bodies As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection(part.ComponentDefinition.SurfaceBodies)
Dim moveDef As MoveDefinition = part.ComponentDefinition.Features.MoveFeatures.CreateMoveDefinition(bodies)
Dim rotation = moveDef.AddRotateAboutAxis(part.ComponentDefinition.WorkAxes(1), True, Math.PI / 2)
part.ComponentDefinition.Features.MoveFeatures.Add(moveDef)
sneha.sadaphal
Is there only this way to do in part environment?
because it will add one move feature in tree structure and also might be origin also will get change.
Michael.Navara
If you don't want to modify the part, you can just re-orient the ViewCube and default views Top, default Isometric, etc.
