How to open an excel file from VBA
jake_egley
jake_egley
I have a macro that fills out an excel spreadsheet and saves it. Now I want it to open the spreadsheet for the user to see when the macro has finished. As opposed to the user going to file explorer to open it after running the macro. I tried several workbooks.open variations and none are working for me. Thank you
Jake Egley
Inventor 2022
marcin_otręba
if you are using excel to fill date then for sure you open it propably invisible ? something like:
Dim XL As Object
Dim xlWS As Object
Set XL = CreateObject("Excel.Application")
XL.Visible = False
then after saving it you can use :
XL.Visible = True
if not then you can use :
Dim XL As Object
Dim xlWS As Object
XL.Workbooks.Open (bomname)
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
jake_egley
Works Great. Thank you. Do you know how to open a file explorer window and make it visible? So when the ilogic is done there is a file explorer window open at the location where my excel file is saved.
Jake Egley
Inventor 2022
A.Acheson
Hi @jake_egley
Try this from this help page on stackoverflow here
Dim Foldername As String
Foldername = "\\server\Instructions\"
Shell "C:\WINDOWS\explorer.exe """ & Foldername & "", vbNormalFocus
Regards
Alan
