How to open a browser window of connected PLM System (ARAS) from Inventor ilogic?
Jakob_Hamburg
Jakob_Hamburg
this is a quite specific question:
We use Inventor with Vault, but on top we have a PLM system called ARAS Innovator.
Our inventor files get a part number from the PLM system by using an add-inn, so the part in Inventor and in PLM-system share the same number.
The PLM-system runs in the web-browser (google chrome).
Unfortunately our add-inn does not support a function to open the part I am working on by one click in the PLM-system.
(I have to copy the part number and go to the plm-system's window in the web-browser and search there for the part)
So my question is: is it possible to open a browser window of connected PLM System (ARAS Innovator) from Inventor ilogic?
I share a screenshot ot the PLM System (ARAS Innovator) because my explanation might be difficult to follow.
JelteDeJong
Opening a web page is not difficult:
Dim webAddress As String = "http://www.example.com/Innovator/client/" & iProperties.Value("Project", "Part Number")
Process.Start(webAddress)
But I did not see a part number in the url. If that is true it means the part number is communicated in a different way and that might be a bigger problem.
Jelte de Jong
Blog: hjalte.nl - github.com
Jakob_Hamburg
Thank you.
Yes, you are totally right, there is no part number in the url. I noticed, too.
I understand that it is the bigger problem to figure out how to communicate the part number to the PLM system.
