How to measure the length of a flange with API
Message 1 of 8
How could I measure the length of a flange with the API.
I thought there would just be a simple FlangeDefinition.WidthExtent.Value
My rule goes something like this (its in VBA but open to iLogic aswel), maybe I'm going about it the wrong way?
Sub Main()
' Get active document
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
' Make sure the active document is a sheet metal document.
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox ("A sheet metal document must be open.")
Exit Sub
End If
' Get component definition of part
Dim oCompDef As SheetMetalComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Get the referenced document feature collection
Dim oFlangesFeatures As PartFeatures
Set oFlangeFeatures = oCompDef.Features.FlangeFeatures
Dim oFlange As FlangeFeature
For Each oFlange In oFlangeFeatures
     Call oFlange.SetEndOfPart(True)
     Dim oDef As FlangeDefinition
     Set oDef = oFlange.Definition
     Dim oEdge As Edge
     For Each oEdge In oDef.Edges
          Dim oExtent As PartFeatureExtent
          Set oExtent = oDef.GetWidthExtent(oEdge)
          Dim oWidth As Double
          ' How do I get width !!! ?????
     Next
Next
End Sub
Replies (7)
Message 2 of 8
perrysc
When you say "length", what exactly do you mean by that? Can you point it out on a test model?
Message 3 of 8
not the height... the length of the edge, which can also be determined by various width extent options (centred, offset, from-to etc)
Message 4 of 8
perrysc
Ah, I see. This should work, I believe.
Sub Main()
Exit Sub
End If
Dim oEdge As Edge
Dim oEdgeStart() As Double
Dim oEdgeEnd() As Double
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oEdgeStartPoint As Point = oTG.CreatePoint(0,0,0)
Dim oEdgeEndPoint As Point = oTG.CreatePoint(0,0,0)
Dim oEdgeWidth As Double For Each oFlange In oFlangeFeatures
oEdge = oFlange.Definition.Edges.Item(1) 'Assumes this is a singled-edged flange.
oEdge.Evaluator.GetEndPoints(oEdgeStart(),oEdgeEnd()) 'Gets the two double arrays that contain the coordinates for the endpoints.
oEdgeStartPoint.PutPointData(oEdgeStart()) 'Sets a Point object at the relevant coordinates.
oEdgeEndPoint.PutPointData(oEdgeEnd()) 'Sets a Point object at the relevant coordinates
oEdgeWidth = oEdgeStartPoint.DistanceTo(oEdgeEndPoint) 'Gets the distance between the two Points Next End Sub
Message 5 of 8
@perrysc thanks for the attempt.
I got these error:
Error on Line 39 : Number of indices is less than the number of dimensions of the indexed array.
Error on Line 40 : Number of indices is less than the number of dimensions of the indexed array.
Error on Line 41 : Number of indices is less than the number of dimensions of the indexed array.
Message 6 of 8
perrysc
Wait, I'm an idiot. Try this now.
Sub Main()
Exit Sub
End If
Dim oEdge As Edge
    oEdge.Evaluator.GetEndPoints(oEdgeStart,oEdgeEnd) 'Gets the two double arrays that contain the coordinates for the endpoints.
    oEdgeStartPoint.PutPointData(oEdgeStart) 'Sets a Point object at the relevant coordinates.
    oEdgeEndPoint.PutPointData(oEdgeEnd) 'Sets a Point object at the relevant coordinates
Next
End Sub
Message 7 of 8
Hi @perrysc
I got this error:
Object reference not set to an instance of an object
Which was generated by this line:
 I figured out the issue though, no edges exist in the flange definition until you set the 'End of Folded' feature node before the flange using:
That took care of the error as it now finds the flange edge, but then I received this error:
Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
Which is generated by this line:
I can't figure that one out Smiley Frustrated
Message 8 of 8
Got it! Had to initialize the values to an empty array, as below
Dim oEdgeStart() As Double = {}
Dim oEdgeEnd() As Double = {}
 Thanks for all your help!
