How to match colors in 3d and 2d drawing?
aplicacoes2
Observer Observer
aplicacoes2
Observer
Observer
Hi.
Could anyone help me to undersand how to create a routine to color the 2d drawing with the same color used in the 3d part/assemble ?
Curtis_Waguespack
Hi @aplicacoes2
See this link:
https://forums.autodesk.com/t5/inventor-forum/update-drawing-line-colour-based-on-part-colour/m-p/74...
I hope this helps.
Curtis
WCrihfield
Are you talking about changing a drawing view's style from either 'Hidden Line' or 'Hidden Line Removed' to 'Shaded'?  If not, please explain better what you are wanting to do.  If you are trying to change the colors of all the little line segments within a drawing view to match the colors of the geometry they represent in the 3D model space, that can get pretty tricky and can take a while to process.  Besides that, 3D models can have all sorts of image or pattern type appearances, so there may not always be just a simple color like red.
Wesley Crihfield
(Not an Autodesk Employee)
