How to loop through, and run all rules that exist in an assembly via iLogic
ABoaro
ABoaro
I am aware of the feature to right click in the Rules browser under 'iLogic' to run all rules. However, I am wondering how that can be done with iLogic rules. Currently, I can only see writing a rule that has a line 'iLogicVb.RunRule("Rule Name")' for every rule as the solution.
This would be very cumbersome to manage if rules get deleted or added down the road to the template that contains these rules. I want to know how a loop can be written to run every rule that exists in the Rules Tab in the iLogic browser.
Any help would be much appreciated.
WCrihfield
Here is a quick and simple example you can use:
Dim oDoc As Document = ThisDoc.Document
Dim oAuto As IiLogicAutomation = iLogicVb.Automation
Dim oRules As IEnumerable = oAuto.Rules(oDoc)
Dim oRule As iLogicRule
For Each oRule In oRules
	oAuto.RunRuleDirect(oRule)
Next
Wesley Crihfield
(Not an Autodesk Employee)
ganesh_omkaar
Where should it write in vb or ilogic
J-Camper
There is not a command for "RunAllRules" but there is a command for "RegenerateAllRules".  See if this is enough for you:
Dim reGen As ButtonDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.RegenAllRules")
reGen.Execute
ABoaro
I have never used the Regenerate Rules feature before. Is there a benefit from regenerating rules as opposed to looping through and running rules? Your method works for all intents and purpose the same as the one mentioned above. The difference it appears is that the regenerate only does rules that are not suppressed. Is there any advantage in that?
J-Camper
I don't know the difference between RunAllRules and RegenerateAllRules.  Inventor Help - work with rules in iLogic stes this about RegenerateAllRules: "This command reconnects the rule to Inventor parameters, recompiles the rule, and then runs it."
I don't think run all rules will run suppressed rules either, at least i think it should leave them alone.
WCrihfield
Here's the slightly modified code that checks if the Rule 'IsActive' (not suppressed) or not.
	If oRule.IsActive Then oAuto.RunRuleDirect(oRule)
Next
Wesley Crihfield
