How to lock a VBA project for viewing?
Message 1 of 14
I'd like to know why I can't lock my VBA project for viewing? Is there something I'm not doing correctly? Is it that the code still available for viewing but not for editing?
Thanks!
Replies (13)
Message 2 of 14
Use the password to lock it from viewing
CVA
www.CVAengineering.com
IV11 Pro. sp2 and IV2008 Pro. sp1
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 91.85
SpacePilot V 3.3.6
wrote in message news:[email protected]...
Thanks!
Message 3 of 14
I know that but it doesn't work. Do I have to exit IV and restart it or completely reboot my computer or anything else?
Message 4 of 14
No need to reboot the computer, just exit the IV and restart it again
When you click on the + sign in fron of the project to expand it, you
should see a pop-up win asking for password - see att. image
However, it's not a very good way to protect the VBA prog. from viewing it.
I'd prefer add-in with more secure.
CVA
Window XP Pro sp2
SpacePilot V 3.3.6
Message 5 of 14
Ok, thanks!
Is it normal that if I lock it, I can't execute it?
Message 6 of 14
No, it's not. You or anyone should be able to execute it, howver, need to
provide password to view it
CVA
Window XP Pro sp2
SpacePilot V 3.3.6
Ok, thanks!
Message 7 of 14
Thanks for your help but it's not the case.
If I lock it, I can't execute it without the password!
Anybody else (maybe from Autodesk) can help me?
Thanks!
Message 8 of 14
sounds to me like you don't have a known entry point. when it's unlocked are
you running by either pressing Alt-F8 in Inventor or running a macro from a
command button? or are you pressing F5 from within the VBA editor? without
seeing some code it's nearly impossible to tell.
joe ...
Thanks!
Message 9 of 14
When it's unlocked, I can run it by either F5 or by a macro from a command button. When I run it by a macro, I use my default VBA project to call the loading of this project and I call to execute the first Sub to start it as follow (I modified the code here to make it easier to read so don't tell me I made syntax mistake or something like this) :
If DragonFlyCharge = False Then 'Project not loaded yet
ThisApplication.VBAProjects.Open("G:\Dessin\Inventor\DragonFly\VBA\DragonFly.ivb")
NombreDeProjets = ThisApplication.VBAProjects.Count
Set MonProjet = ThisApplication.VBAProjects.Item(NombreDeProjets)
End If
MonProjet.InventorVBAComponents.Item("DragonFlyStart").InventorVBAMembers.Item("DragonFly").Execute
It works just fine as long as I don't lock the project with a password. As soon as I lock it, the code stops at the last line which is suppose to execute the Sub "DragonFly".
Message 10 of 14
is the sub your calling to run your application declared as public?
joe ...
End If
Message 11 of 14
Yes. As I said, the code stops only when I lock the project... Everything works fine as long as the project is unlocked. Autodesk already saw something similar?
Message 12 of 14
i just tried one in 2008 sp1 and had no problem with running the sub. i have
to believe that it has something to do with where your sub is declared or
how you have it declared. perhaps if you post the first line of the sub and
the exact name of the module where the sub resides? what version of iv as
well and any sp's.
joe ...
something similar?
Message 13 of 14
Using IV 11 Pro SP3, here is the code for my module "Module_ChargeDragonFly":
(My command button calls directly "ChargeDragonFly")
Option Explicit
'Cette Sub permet de charger le projet DragonFly s'il n'est pas déjà chargé
Public Sub ChargeDragonFly()
Dim NombreDeProjets As Integer
Dim DragonFlyCharge As Boolean
Dim MesProjets As InventorVBAProjects
Dim MonProjet As InventorVBAProject
Set MesProjets = ThisApplication.VBAProjects
For Each MonProjet In MesProjets
If Right(MonProjet.VBProject.FileName, 13) = "DragonFly.ivb" Then
DragonFlyCharge = True
Exit For
End If
Next
'Spécifier le nom du .ivb à charger
ThisApplication.VBAProjects.Open ("G:\Dessin\Inventor\DragonFly\VBA\DragonFly.ivb")
End If
'Nom du module 'Nom de la public sub
End Sub
Thanks!
Message 14 of 14
did you install or uninstall any office products since you installed
inventor?
if so, i would suggest re-installing inventor.
joe ...
Option Explicit
Exit For
End If
Next
End If
'Nom du module
End Sub
Thanks!
