How to launch File Number Generator in Inventor by VB.Net
MaciejWojda
MaciejWojda
I have created addin in VB.Net with customized saving parts and assemblies. Everything works fine, but the problem is that my customer also has Vault and needs to have this Generate File Number window opened after Saving As.
My code does not make it appear. How can I do that?
The best scenario is that this generator opens and after clicking "Ok" it handles generated file number itself. But I suppose that it might demand also handling like in case of opening SaveAs dialog box that in fact does not save, but only takes the full path of new file and then it has to be saved also with code.
Every help is much appreciated.
theo.bot
You could get the number from vault by using the Ilogic-Vault Quickstart library.
Here is the presentation about the functions:
iLogic-Vault/Inventor iLogic - Vault Quickstart Library.pdf at 2022 · koechlm/iLogic-Vault · GitHub
GitHub - koechlm/iLogic-Vault: iLogic Rules, Snippets and iLogic-Vault Quickstart library
lukasz.przybysz
How can i open generate number file form? Can i do that?
