How to include plane in a drawing View
I have adrawing view with many recurring instances of the same part. I want to include the "XY Plane of each of these occurrences using the API. My code appears to be correct but the projected planes just won't show up. I get an error when I try to include the plane that is not normal the the view so I know it is doing something. Any suggestions?
philippe.leefsma
Did you try to replace
     Call oDrawingDoc.Sheets(1).DrawingViews(1).SetVisibility(oWPpx, False)
with
     Call oDrawingDoc.Sheets(1).DrawingViews(1).SetVisibility(oWPpx, True)
The code works fine on my side.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
