Message 1 of 1
How to Include Matchlist for Composite imate
01:53 PM
Hi All,
I have automated generation of imates with user interaction for some series of Parts. One part is attached here. If I don't include MatchList for Composite imates it works fine but Including Matchlist for composite imate gives me Run-time Error '5': Invalid Procedure Call or Argument. Can anybody help me please?
Working on Inventor 2017
Regards,Jitenkumar
Unable to attach form here so sharing a pic
Form - Form_Imate_Creator_FB
Private Sub UserForm_Initialize() PopCoB_ElmtType CoB_ElmtType.ListIndex = 0 End Sub Private Sub PopCoB_ElmtType() CoB_ElmtType.Clear 'Initialise Raw Material Form Combo Box CoB_ElmtType.AddItem "8 Port Block" CoB_ElmtType.AddItem "4 Port Block" CoB_ElmtType.AddItem "M12 5Pin Conn Male" CoB_ElmtType.AddItem "M12 4Pin Conn Male" CoB_ElmtType.AddItem "M12 4Pin Conn Female" CoB_ElmtType.AddItem "M12 5Pin Conn Female" End Sub Private Sub CoBu_Exit_Click() FBiMC.Kill = True Unload Me End Sub Private Sub CoBu_Apply_Click() FBiMC.ElmtType = CoB_ElmtType.Value Unload Me End Sub
Main Module
Public Type FBiMCObj_Datatype 'used in Cls_GetSelObj_FB as well hence public IMObject As Object IMBiasPoint As Point End Type Public Type FBiMC_DataType Doc As Document ElmtType As String Kill As Boolean Esc As Boolean End Type Public FBiMC As FBiMC_DataType Dim N_iports As Integer Sub Imate_Creator_FB() Set FBiMC.Doc = ThisApplication.ActiveDocument If FBiMC.Doc.DocumentType = kPartDocumentObject Xor kAssemblyDocumentObject Then 'Pass Else MsgBox "File Type Not Compatible. Please Use a Part or an Assembly File" Exit Sub End If FBiMC.Kill = False FBiMC.Esc = False Form_Imate_Creator_FB.Show If FBiMC.Kill Then Exit Sub ' just to cut short the calculation time. Create_iMate any way terminates on FBiMC.Kill CreateiMates FBiMC.Doc, FBiMC.ElmtType End Sub Sub CreateiMates(ByRef sDoc As Document, ByVal sElmtType As String) Dim Compdef As ComponentDefinition Dim iMateColl As ObjectCollection Dim CiMateMatchList() As String Dim Offset As String Dim mate As iMateDefinition Dim CMate As CompositeiMateDefinition Dim a As Integer Set Compdef = sDoc.ComponentDefinition Select Case FBiMC.ElmtType Case "8 Port Block": N_iports = 8 Case "4 Port Block": N_iports = 4 End Select Set iMateColl = ThisApplication.TransientObjects.CreateObjectCollection Select Case FBiMC.ElmtType Case "8 Port Block", "4 Port Block" Set mate = Create_iMate(sDoc, sElmtType, "Port-A M12 6P Male", "M12 6P Insert", "Insert", "0 in", True) If FBiMC.Kill = False Then iMateColl.Add mate Else Exit Sub Set mate = Create_iMate(sDoc, sElmtType, "Port-A M12 6P Male", "M12 6P Orientation", "Angle", "180 deg", True) If FBiMC.Kill = False Then iMateColl.Add mate Else Exit Sub CiMateMatchList = Create_CiMatchList("Port-A M12 6P Male", sElmtType) 'Debug.Print UBound(CiMateMatchList, 1) & CiMateMatchList(0) If IsArrayInitialized(CiMateMatchList) Then Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Male", CiMateMatchList) Else Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Male") End If iMateColl.Clear Set mate = Create_iMate(sDoc, sElmtType, "Port-B M12 6P Female", "M12 6P Insert", "Insert", "0 in", True) If FBiMC.Kill = False Then iMateColl.Add mate Else Exit Sub Set mate = Create_iMate(sDoc, sElmtType, "Port-B M12 6P Female", "M12 6P Orientation", "Angle", "180 deg", True) If FBiMC.Kill = False Then iMateColl.Add mate Else Exit Sub CiMateMatchList = Create_CiMatchList("Port-A M12 6P Female", sElmtType) If IsArrayInitialized(CiMateMatchList) Then Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Female", CiMateMatchList) Else Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Female") End If iMateColl.Clear For a = 0 To N_iports - 1 iMateColl.Clear Set mate = Create_iMate(sDoc, sElmtType, "Port-" & a & " M12 5P Female", "M12 4P/5P Insert", "Insert", "0.001 in", True) If FBiMC.Kill = False Then iMateColl.Add mate Else Exit Sub Set mate = Create_iMate(sDoc, sElmtType, "Port-" & a & " M12 5P Female", "M12 4P/5P Orientation", "Angle", "180 deg", True) If FBiMC.Kill = False Then iMateColl.Add mate Else Exit Sub CiMateMatchList = Create_CiMatchList("Port-" & a & " M12 5P Female", sElmtType) If IsArrayInitialized(CiMateMatchList) Then Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-" & a & " M12 5P Female", CiMateMatchList) Else Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-" & a & " M12 5P Female") End If Next a End Select End Sub Function Create_CiMatchList(ByVal f_CiMateName, f_ElmtType As String) As String() Dim MatchList() As String Dim a As Integer Erase MatchList Select Case f_ElmtType Case "8 Port Block", "4 Port Block" Select Case f_CiMateName Case "Port-A M12 6P Male" ReDim MatchList(0) MatchList(0) = "M12 6P Female" Case "Port-B M12 6P Female" ReDim MatchList(0) MatchList(0) = "M12 6P Male" End Select For a = 0 To N_iports - 1 If f_CiMateName = "Port-" & a & " M12 6P Female" Then ReDim MatchList(1) MatchList(0) = "M12 4P Male" MatchList(1) = "M12 5P Male" End If Next a Case Else End Select Create_CiMatchList = MatchList End Function Function Create_MatchList(ByVal f_CiMateName, f_iMateName, f_ElmtType As String) As String() Dim MatchList() As String Dim a As Integer Erase MatchList Select Case f_ElmtType Case "8 Port Block", "4 Port Block" Select Case f_CiMateName Case "Port-A M12 6P Male" Select Case f_iMateName Case "M12 6P Insert" ReDim MatchList(0) MatchList(0) = "M12 6P Female Insert" Case "M12 6P Orientation" ReDim MatchList(0) MatchList(0) = "M12 6P Female Orientation" Case Else End Select Case "Port-B M12 6P Female" Select Case f_iMateName Case "M12 6P Insert" ReDim MatchList(0) MatchList(0) = "M12 6P Male Insert" Case "M12 6P Orientation" ReDim MatchList(0) MatchList(0) = "M12 6P Male Orientation" Case Else End Select End Select For a = 0 To N_iports - 1 If f_CiMateName = "Port-" & a & " M12 5P Female" Then Select Case f_iMateName Case "M12 4P/5P Insert" ReDim MatchList(1) MatchList(0) = "M12 4P Male Insert" MatchList(1) = "M12 5P Male Insert" Case "M12 4P/5P Orientation" ReDim MatchList(1) MatchList(0) = "M12 4P Male Orientation" MatchList(1) = "M12 5P Male Orientation" Case Else End Select End If Next a Case "M12 6Pin Conn" Select Case f_CiMateName Case "M12 6P Male" Select Case f_iMateName Case "M12 6P Insert" ReDim MatchList(2) MatchList(0) = "Port-A M12 6P Female Insert" MatchList(1) = "Port-B M12 6P Female Insert" MatchList(2) = "M12 6P Female Insert" Case "M12 6P Orientation" ReDim MatchList(2) MatchList(0) = "Port-A M12 6P Female Orientation" MatchList(1) = "Port-B M12 6P Female Orientation" MatchList(2) = "M12 6P Female Orientation" Case Else End Select Case "M12 6P Female" Select Case f_iMateName Case "M12 6P Insert" ReDim MatchList(2) MatchList(0) = "Port-A M12 6P Male Insert" MatchList(1) = "Port-B M12 6P Male Insert" MatchList(2) = "M12 6P Male Insert" Case "M12 6P Orientation" ReDim MatchList(2) MatchList(0) = "Port-A M12 6P Male Orientation" MatchList(1) = "Port-B M12 6P Male Orientation" MatchList(2) = "M12 6P Male Orientation" Case Else End Select Case Else End Select Case "M12 5Pin Conn" Select Case f_CiMateName Case "M12 5P Male" Select Case f_iMateName Case "M12 4P/5P Insert" ReDim MatchList(8) MatchList(0) = "Port-0 M12 5P Female Insert" MatchList(1) = "Port-1 M12 5P Female Insert" MatchList(2) = "Port-2 M12 5P Female Insert" MatchList(3) = "Port-3 M12 5P Female Insert" MatchList(4) = "Port-4 M12 5P Female Insert" MatchList(5) = "Port-5 M12 5P Female Insert" MatchList(6) = "Port-6 M12 5P Female Insert" MatchList(7) = "Port-7 M12 5P Female Insert" MatchList(8) = "M12 5P Female Insert" Case "M12 5P Orientation" ReDim MatchList(8) MatchList(0) = "Port-0 M12 5P Female Orientation" MatchList(1) = "Port-1 M12 5P Female Orientation" MatchList(2) = "Port-2 M12 5P Female Orientation" MatchList(3) = "Port-3 M12 5P Female Orientation" MatchList(4) = "Port-4 M12 5P Female Orientation" MatchList(5) = "Port-5 M12 5P Female Orientation" MatchList(6) = "Port-6 M12 5P Female Orientation" MatchList(7) = "Port-7 M12 5P Female Orientation" MatchList(8) = "M12 5P Female Orientation" Case Else End Select Case "M12 5P Female" Select Case f_iMateName Case "M12 4P/5P Insert" ReDim MatchList(8) MatchList(0) = "Port-0 M12 5P Male Insert" MatchList(1) = "Port-1 M12 5P Male Insert" MatchList(2) = "Port-2 M12 5P Male Insert" MatchList(3) = "Port-3 M12 5P Male Insert" MatchList(4) = "Port-4 M12 5P Male Insert" MatchList(5) = "Port-5 M12 5P Male Insert" MatchList(6) = "Port-6 M12 5P Male Insert" MatchList(7) = "Port-7 M12 5P Male Insert" MatchList(8) = "M12 5P Male Insert" Case "M12 5P Orientation" ReDim MatchList(8) MatchList(0) = "Port-0 M12 5P Male Orientation" MatchList(1) = "Port-1 M12 5P Male Orientation" MatchList(2) = "Port-2 M12 5P Male Orientation" MatchList(3) = "Port-3 M12 5P Male Orientation" MatchList(4) = "Port-4 M12 5P Male Orientation" MatchList(5) = "Port-5 M12 5P Male Orientation" MatchList(6) = "Port-6 M12 5P Male Orientation" MatchList(7) = "Port-7 M12 5P Male Orientation" MatchList(8) = "M12 5P Male Orientation" Case Else End Select Case Else End Select Case "M12 4Pin Conn" Select Case f_CiMateName Case "M12 4P Male" Select Case f_iMateName Case "M12 4P/5P Insert" ReDim MatchList(9) MatchList(0) = "Port-0 M12 5P Female Insert" MatchList(1) = "Port-1 M12 5P Female Insert" MatchList(2) = "Port-2 M12 5P Female Insert" MatchList(3) = "Port-3 M12 5P Female Insert" MatchList(4) = "Port-4 M12 5P Female Insert" MatchList(5) = "Port-5 M12 5P Female Insert" MatchList(6) = "Port-6 M12 5P Female Insert" MatchList(7) = "Port-7 M12 5P Female Insert" MatchList(8) = "M12 4P Female Insert" MatchList(9) = "M12 5P Female Insert" Case "M12 5P Orientation" ReDim MatchList(9) MatchList(0) = "Port-0 M12 5P Female Orientation" MatchList(1) = "Port-1 M12 5P Female Orientation" MatchList(2) = "Port-2 M12 5P Female Orientation" MatchList(3) = "Port-3 M12 5P Female Orientation" MatchList(4) = "Port-4 M12 5P Female Orientation" MatchList(5) = "Port-5 M12 5P Female Orientation" MatchList(6) = "Port-6 M12 5P Female Orientation" MatchList(7) = "Port-7 M12 5P Female Orientation" MatchList(8) = "M12 4P Female Orientation" MatchList(9) = "M12 5P Female Orientation" Case Else End Select Case "M12 4P Female" Select Case f_iMateName Case "M12 4P/5P Insert" ReDim MatchList(9) MatchList(0) = "Port-0 M12 5P Male Insert" MatchList(1) = "Port-1 M12 5P Male Insert" MatchList(2) = "Port-2 M12 5P Male Insert" MatchList(3) = "Port-3 M12 5P Male Insert" MatchList(4) = "Port-4 M12 5P Male Insert" MatchList(5) = "Port-5 M12 5P Male Insert" MatchList(6) = "Port-6 M12 5P Male Insert" MatchList(7) = "Port-7 M12 5P Male Insert" MatchList(8) = "M12 4P Male Insert" MatchList(9) = "M12 5P Male Insert" Case "M12 5P Orientation" ReDim MatchList(9) MatchList(0) = "Port-0 M12 5P Male Orientation" MatchList(1) = "Port-1 M12 5P Male Orientation" MatchList(2) = "Port-2 M12 5P Male Orientation" MatchList(3) = "Port-3 M12 5P Male Orientation" MatchList(4) = "Port-4 M12 5P Male Orientation" MatchList(5) = "Port-5 M12 5P Male Orientation" MatchList(6) = "Port-6 M12 5P Male Orientation" MatchList(7) = "Port-7 M12 5P Male Orientation" MatchList(8) = "M12 4P Male Orientation" MatchList(9) = "M12 5P Male Orientation" Case Else End Select Case Else End Select Case Else End Select Create_MatchList = MatchList End Function 's_Direction works only when Insert, Tangent and Angle mates Function Create_iMate(ByRef s_Doc As Document, ByVal s_ElmtType As String, ByVal s_CiMateName, s_iMateName, s_iMateType, s_Offset As String, ByVal s_Direction As Boolean) As iMateDefinition Dim oPCompDef As PartComponentDefinition Dim oACompDef As AssemblyComponentDefinition Dim sObjData As FBiMCObj_Datatype Dim No_sObjData As FBiMCObj_Datatype Dim nBiasPoint As Point Dim nObject As Object Dim nface As Face Dim nAxis As Axis Dim nEdge As Object Dim niMateSuccess As Boolean Dim oselectedobject As New Cls_GetSelObj_FB Dim oMateiMateDefinition As MateiMateDefinition Dim oInsertiMateDefinition As InsertiMateDefinition Dim oFlushiMateDefinition As FlushiMateDefinition Dim oTangentiMateDefinition As TangentiMateDefinition Dim oAngleiMateDefinition As AngleiMateDefinition Dim oiMateMatchList() As String If FBiMC.Kill Then Exit Function If s_Doc.DocumentType = kPartDocumentObject Then Set oPCompDef = s_Doc.ComponentDefinition If s_Doc.DocumentType = kAssemblyDocumentObject Then Set oACompDef = s_Doc.ComponentDefinition oiMateMatchList = Create_MatchList(s_CiMateName, s_iMateName, s_ElmtType) Select Case s_iMateType Case "Mate": niMateSuccess = False: FBiMC.Esc = False Do If FBiMC.Esc Or FBiMC.Kill Then Exit Do On Error Resume Next sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Planar Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType) Set nObject = sObjData.IMObject Set nBiasPoint = sObjData.IMBiasPoint ' Select Case nObject.Type ' Case kEdgeProxyObject, kEdgeObject ' Case Else ' Dim dCurrent(2) As Double ' Dim adEye(2) As Double ' adEye(0) = 0 ' adEye(1) = 0 ' adEye(2) = 0 ' Dim adGuessparams() As Double ' Dim adMaxDeviations() As Double ' Dim adParams(1) As Double ' Dim aenSolTypes() As SolutionNatureEnum ' Call nObject.Evaluator.GetParamAtPoint(adEye, adGuessparams, adMaxDeviations, adParams, aenSolTypes) ' If err Then MsgBox err.Description ' MsgBox adParams(0) & "," & adParams(1) & "-" & aenSolTypes(0) ' Call nObject.Evaluator.GetPointAtParam(adParams, dCurrent) ' MsgBox nBiasPoint.X & "," & nBiasPoint.Y & "," & nBiasPoint.Z & vbCrLf & dCurrent(0) & "," & dCurrent(1) & "," & dCurrent(2) ' nBiasPoint.X = nBiasPoint.X - dCurrent(0) ' nBiasPoint.Y = nBiasPoint.Y - dCurrent(1) ' nBiasPoint.Z = nBiasPoint.Z - dCurrent(2) ' End Select If Err Then MsgBox Err.Description & ":Probably Object or Bias Point not selected", vbCritical, Err.Number & ":" & s_iMateName: Exit Function On Error GoTo 0 'Set nface = ThisApplication.CommandManager.Pick(kPartFacePlanarFilter, s_iMateName & ":Select a Planar Face.") If Not nObject Is Nothing Then Select Case nObject.Type Case kFaceProxyObject, kFaceObject, kWorkPlaneProxyObject, kWorkPlaneObject Select Case s_Doc.DocumentType Case kPartDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , nBiasPoint, s_iMateName, oiMateMatchList) Else Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , nBiasPoint, s_iMateName) End If Case kAssemblyDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , , s_iMateName, oiMateMatchList) Else Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , , s_iMateName) End If End Select niMateSuccess = True Case Else: MsgBox " Selected Feature failed for selected imate", vbCritical, s_iMateName End Select End If Loop While niMateSuccess = False sObjData = No_sObjData Set Create_iMate = oMateiMateDefinition Case "Axis": niMateSuccess = False: FBiMC.Esc = False Do If FBiMC.Esc Or FBiMC.Kill Then Exit Do On Error Resume Next sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Cylindrical Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType) Set nObject = sObjData.IMObject Set nBiasPoint = sObjData.IMBiasPoint If Err Then MsgBox Err.Description & ":Probably Object or Bias Point not selected", vbCritical, Err.Number & ":" & s_iMateName: Exit Function On Error GoTo 0 If Not nObject Is Nothing Then Select Case nObject.Type Case kFaceProxyObject, kFaceObject If nObject.SurfaceType = kCylinderSurface Or nObject.SurfaceType = kConeSurface Then Select Case s_Doc.DocumentType Case kPartDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName, oiMateMatchList) Else Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName) End If Case kAssemblyDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName, oiMateMatchList) Else Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName) End If End Select niMateSuccess = True Else: MsgBox "Selected Feature not a cylinderical face", vbCritical, s_iMateName End If Case Else: MsgBox " Selected Feature failed for selected imate", vbCritical, s_iMateName End Select End If Loop While niMateSuccess = False sObjData = No_sObjData Set Create_iMate = oMateiMateDefinition Case "Flush" niMateSuccess = False: FBiMC.Esc = False Do If FBiMC.Esc Or FBiMC.Kill Then Exit Do On Error Resume Next sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Planar Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType) Set nObject = sObjData.IMObject Set nBiasPoint = sObjData.IMBiasPoint If Err Then MsgBox Err.Description & ":Probably Object or Bias Point not selected", vbCritical, Err.Number & ":" & s_iMateName: Exit Function On Error GoTo 0 If Not nObject Is Nothing Then Select Case nObject.Type Case kFaceProxyObject, kFaceObject, kWorkPlaneProxyObject, kWorkPlaneObject Select Case s_Doc.DocumentType Case kPartDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oFlushiMateDefinition = oPCompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName, oiMateMatchList) Else Set oFlushiMateDefinition = oPCompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName) End If Case kAssemblyDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oFlushiMateDefinition = oACompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName, oiMateMatchList) Else Set oFlushiMateDefinition = oACompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName) End If End Select niMateSuccess = True Case Else: MsgBox " Selected Feature failed for selected imate", vbCritical, s_iMateName End Select End If Loop While niMateSuccess = False sObjData = No_sObjData Set Create_iMate = oFlushiMateDefinition Case "Insert": niMateSuccess = False: FBiMC.Esc = False Do If FBiMC.Esc Or FBiMC.Kill Then Exit Do On Error Resume Next sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Circular Edge or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType) Set nObject = sObjData.IMObject Set nBiasPoint = sObjData.IMBiasPoint If Err Then MsgBox Err.Description & ":Probably Object or Bias Point not selected", vbCritical, Err.Number & ":" & s_iMateName: Exit Function On Error GoTo 0 If Not nObject Is Nothing Then Select Case nObject.Type Case kEdgeProxyObject, kEdgeObject Select Case nObject.GeometryType Case kCircleCurve, kCircularArcCurve Select Case s_Doc.DocumentType Case kPartDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oInsertiMateDefinition = oPCompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oInsertiMateDefinition = oPCompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If Case kAssemblyDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oInsertiMateDefinition = oACompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oInsertiMateDefinition = oACompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If End Select niMateSuccess = True Case Else: MsgBox " Selected Feature not a Circular edge", vbCritical, s_iMateName End Select Case Else: MsgBox " Selected Feature not an edge", vbCritical, s_iMateName End Select End If Loop While niMateSuccess = False sObjData = No_sObjData Set Create_iMate = oInsertiMateDefinition Case "Tangent": niMateSuccess = False: FBiMC.Esc = False Do If FBiMC.Esc Or FBiMC.Kill Then Exit Do On Error Resume Next If FBiMC.ElmtType <> Fitting Then sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Cylindrical Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType) Else sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select a Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType) End If Set nObject = sObjData.IMObject Set nBiasPoint = sObjData.IMBiasPoint If Err Then MsgBox Err.Description & ":Probably Object or Bias Point not selected", vbCritical, Err.Number & ":" & s_iMateName: Exit Function On Error GoTo 0 If Not nObject Is Nothing Then Select Case nObject.Type Case kFaceProxyObject, kFaceObject If FBiMC.ElmtType <> "Fitting" Then If nObject.SurfaceType = kCylinderSurface Then If Not IsCylindricalFaceInterior(nObject) Then Select Case s_Doc.DocumentType Case kPartDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oTangentiMateDefinition = oPCompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oTangentiMateDefinition = oPCompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If Case kAssemblyDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oTangentiMateDefinition = oACompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oTangentiMateDefinition = oACompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If End Select niMateSuccess = True Else: MsgBox "Selected Feature not an External cylinderical face", vbCritical End If Else: MsgBox "Selected Feature not a cylinderical face", vbCritical, s_iMateName End If Else Select Case s_Doc.DocumentType Case kPartDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oTangentiMateDefinition = oPCompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oTangentiMateDefinition = oPCompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If Case kAssemblyDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oTangentiMateDefinition = oACompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oTangentiMateDefinition = oACompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If End Select niMateSuccess = True End If Case Else: MsgBox " Selected Feature is not a face", vbCritical, s_iMateName End Select End If Loop While niMateSuccess = False sObjData = No_sObjData Set Create_iMate = oTangentiMateDefinition Case "Angle" niMateSuccess = False: FBiMC.Esc = False Do If FBiMC.Esc Or FBiMC.Kill Then Exit Do On Error Resume Next sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Planar Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType) Set nObject = sObjData.IMObject Set nBiasPoint = sObjData.IMBiasPoint If Err Then MsgBox Err.Description & ":Probably Object or Bias Point not selected", vbCritical, Err.Number & ":" & s_iMateName: Exit Function On Error GoTo 0 If Not nObject Is Nothing Then Select Case nObject.Type Case kFaceProxyObject, kFaceObject, kWorkPlaneProxyObject, kWorkPlaneObject ' needs to be tested thoroughly Select Case s_Doc.DocumentType Case kPartDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oAngleiMateDefinition = oPCompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oAngleiMateDefinition = oPCompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If Case kAssemblyDocumentObject: If IsArrayInitialized(oiMateMatchList) Then Set oAngleiMateDefinition = oACompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList) Else Set oAngleiMateDefinition = oACompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName) End If End Select niMateSuccess = True Case Else: MsgBox " Selected Feature failed for selected imate", vbCritical, s_iMateName End Select End If Loop While niMateSuccess = False sObjData = No_sObjData Set Create_iMate = oAngleiMateDefinition End Select End Function Function IsArrayInitialized(a) As Boolean Dim i As Integer Err.Clear On Error Resume Next i = UBound(a) If (Err.Number = 0) Then IsArrayInitialized = True Else IsArrayInitialized = False End If On Error GoTo 0 End Function Function IsCylindricalFaceInterior(ByVal oFace As Face) As Boolean If Not oFace.SurfaceType = kCylinderSurface Then MsgBox "A cylindrical face must be selected." Exit Function End If Dim oCylinder As Cylinder Set oCylinder = oFace.Geometry Dim params(1) As Double params(0) = 0.5 params(1) = 0.5 ' Get point on surface at param .5,.5 Dim points(2) As Double Call oFace.Evaluator.GetPointAtParam(params, points) ' Create point object Dim oPoint As Point Set oPoint = ThisApplication.TransientGeometry.CreatePoint(points(0), points(1), points(2)) ' Get normal at this point Dim normals(2) As Double Call oFace.Evaluator.GetNormal(params, normals) ' Create normal vector object Dim oNormal As Vector Set oNormal = ThisApplication.TransientGeometry.CreateVector(normals(0), normals(1), normals(2)) ' Scale vector by radius of the cylinder oNormal.ScaleBy oCylinder.Radius ' Find the sampler point on the normal by adding the ' scaled normal vector to the point at .5,.5 param. Dim oSamplePoint As Point Set oSamplePoint = oPoint oSamplePoint.TranslateBy oNormal ' Check if the sample point lies on the cylinder axis. ' If it does, we have a hollow face. ' Create a line describing the cylinder axis Dim oAxisLine As Line Set oAxisLine = ThisApplication.TransientGeometry.CreateLine(oCylinder.BasePoint, oCylinder.AxisVector.AsVector) 'Create a line parallel to the axis passing thru the sample point. Dim oSampleLine As Line Set oSampleLine = ThisApplication.TransientGeometry.CreateLine(oSamplePoint, oCylinder.AxisVector.AsVector) If oSampleLine.IsColinearTo(oAxisLine) Then 'MsgBox "Interior face." IsCylindricalFaceInterior = True Else 'MsgBox "Exterior face." IsCylindricalFaceInterior = False End If End Function
Class Module - Cls_GetSelObj_FB
'Public Variables used - 'Imate_Creator_Pn :- FBiMC.Kill,FBiMC.Esc '-----------------------XXXXXXXX----------------- 'References Used - 'Imate_Creator_Pn :- FBiMCObj_Datatype '-----------------------XXXXXXXX----------------- 'Referenced by - 'Imate_Creator_Pn 'Form_Imate_Creator_Pn '-----------------------XXXXXXXX----------------- Private WithEvents oInteractionEvents As InteractionEvents Private WithEvents i_MouseEvents As MouseEvents Private WithEvents i_SelectEvents As SelectEvents Private WithEvents i_KeyboardEvents As KeyboardEvents Private WithEvents uiEvents As UserInputEvents Private bStillSelecting As Boolean Private iObject As Object Private iPoint As Point Private iFace, iOFace As Face Private iAxis As Axis Private iEdge, iOEdge As Edge Public Function GetFace(ByVal f_Doc As Document, f_Status As String) As Face f_Doc.SelectSet.Clear ' Create interaction events Set oInteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents oInteractionEvents.StatusBarText = f_Status Set i_KeyboardEvents = oInteractionEvents.KeyboardEvents Set i_MouseEvents = oInteractionEvents.MouseEvents Set i_SelectEvents = oInteractionEvents.SelectEvents i_SelectEvents.ResetSelections i_SelectEvents.ClearSelectionFilter i_SelectEvents.SingleSelectEnabled = True i_SelectEvents.Enabled = True i_SelectEvents.AddSelectionFilter kPartFacePlanarFilter i_SelectEvents.AddSelectionFilter kWorkPlaneFilter bStillSelecting = True oInteractionEvents.Start Do While bStillSelecting DoEvents Loop Set GetFace = iFace End Function Public Function GetOFace(ByVal f_Doc As Document, f_Status As String) As Face f_Doc.SelectSet.Clear ' Create interaction events Set oInteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents oInteractionEvents.StatusBarText = f_Status Set i_KeyboardEvents = oInteractionEvents.KeyboardEvents Set i_SelectEvents = oInteractionEvents.SelectEvents i_SelectEvents.ResetSelections i_SelectEvents.SingleSelectEnabled = True i_SelectEvents.Enabled = True i_SelectEvents.ClearSelectionFilter i_SelectEvents.AddSelectionFilter kPartFaceCylindricalFilter i_SelectEvents.AddSelectionFilter kPartFaceConicalFilter bStillSelecting = True oInteractionEvents.Start Do While bStillSelecting DoEvents Loop Set GetOFace = iOFace End Function Public Function GetOEdge(ByVal f_Doc As Document, f_Status As String) As Edge f_Doc.SelectSet.Clear ' Create interaction events Set oInteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents oInteractionEvents.StatusBarText = f_Status Set i_KeyboardEvents = oInteractionEvents.KeyboardEvents Set i_SelectEvents = oInteractionEvents.SelectEvents i_SelectEvents.ResetSelections i_SelectEvents.ClearSelectionFilter i_SelectEvents.SingleSelectEnabled = True i_SelectEvents.Enabled = True i_SelectEvents.AddSelectionFilter kPartEdgeCircularFilter bStillSelecting = True oInteractionEvents.Start Do While bStillSelecting DoEvents Loop Set GetOEdge = iOEdge End Function 'Public Function Get_Object(ByVal f_Doc As Document, ByVal f_Status, i_iMatetype As String) As Object ' WIP Public Function Get_SObject(ByVal f_Doc As Document, ByVal f_Status, i_iMatetype, f_ElementType As String) As FBiMCObj_Datatype ' WIP FBiMC.Esc = False f_Doc.SelectSet.Clear ' Create interaction events Set oInteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents oInteractionEvents.StatusBarText = f_Status 'oInteractionEvents.InteractionDisabled = False Set i_KeyboardEvents = oInteractionEvents.KeyboardEvents Set i_SelectEvents = oInteractionEvents.SelectEvents i_SelectEvents.ResetSelections i_SelectEvents.ClearSelectionFilter i_SelectEvents.SingleSelectEnabled = True i_SelectEvents.Enabled = True Select Case i_iMatetype Case "Mate", "Flush": i_SelectEvents.AddSelectionFilter kPartFacePlanarFilter Case "Angle": i_SelectEvents.AddSelectionFilter kPartFacePlanarFilter i_SelectEvents.AddSelectionFilter kWorkPlaneFilter Case "Axis": i_SelectEvents.AddSelectionFilter kPartFaceCylindricalFilter ' To be changed here to Axis Selection Filter right now workaround is by selecting face i_SelectEvents.AddSelectionFilter kPartFaceConicalFilter Case "Tangent": If f_ElementType <> "Fitting" Then i_SelectEvents.AddSelectionFilter kPartFaceCylindricalFilter 'i_SelectEvents.AddSelectionFilter kPartFaceConicalFilter Else i_SelectEvents.AddSelectionFilter kPartFacePlanarFilter End If Case "Insert": i_SelectEvents.AddSelectionFilter kPartEdgeCircularFilter End Select bStillSelecting = True oInteractionEvents.Start Do While bStillSelecting DoEvents Loop Set Get_SObject.IMObject = iObject Set Get_SObject.IMBiasPoint = iPoint 'Suppress in case function returns Object instead of FBiMCObj_Datatype 'MsgBox Get_SObject.IMBiasPoint.X & "," & Get_SObject.IMBiasPoint.Y & "," & Get_SObject.IMBiasPoint.Z End Function Private Sub i_SelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) Set iPoint = ModelPosition On Error Resume Next Set iObject = i_SelectEvents.SelectedEntities(1) Set iFace = i_SelectEvents.SelectedEntities(1) Set iOFace = i_SelectEvents.SelectedEntities(1) Set iAxis = i_SelectEvents.SelectedEntities(1) 'Set iEdge = i_Selectevents.SelectedEntities(1) Set iOEdge = i_SelectEvents.SelectedEntities(1) On Error GoTo 0 bStillSelecting = False End Sub Private Sub i_MouseEvents_OnMouseClick(ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View) Set iPoint = ModelPosition bStillSelecting = False End Sub Private Sub i_KeyboardEvents_OnKeyPress(ByVal KeyAscii As Long) Dim i As Integer If KeyAscii = 113 Or KeyAscii = 81 Then ' Ascii Code for "q" and "Q" i = MsgBox("Do you want to escape creating this iMate", vbQuestion + vbDefaultButton2 + vbAbortRetryIgnore) 'Selecting no here does go back to control. needs to be sorted out. Select Case i Case 5: bStillSelecting = False: FBiMC.Esc = True Case 4: bStillSelecting = True Case 3: FBiMC.Kill = True: bStillSelecting = False End Select End If End Sub Private Sub oInteractionEvents_OnTerminate() ' on Keypress esc Dim i As Integer i = MsgBox("Terminating the Interaction Process", vbCritical + vbOKOnly) 'Option to return not working as selection filter fails here perhaps interaction event dies here Select Case i Case 5: bStillSelecting = False Case 4: bStillSelecting = True Case 1: FBiMC.Kill = True: bStillSelecting = False End Select End Sub Private Sub uiEvents_OnTerminateCommand(ByVal CommandName As String, ByVal Context As NameValueMap) Set uiEvents = Nothing Dim i As Integer i = MsgBox("Do you want to escape creating this iMate", vbQuestion + vbDefaultButton2 + vbAbortRetryIgnore, CommandName) Select Case i Case 5: bStillSelecting = False: FBiMC.Esc = True Case 4: bStillSelecting = True Case 3: FBiMC.Kill = True: bStillSelecting = False End Select End Sub
