How to Include Matchlist for Composite imate
Message 1 of 1
Hi All,
I have automated generation of imates with user interaction for some series of Parts. One part is attached here. If I don't include MatchList for Composite imates it works fine but Including Matchlist for composite imate gives me Run-time Error '5': Invalid Procedure Call or Argument. Can anybody help me please?
Working on Inventor 2017
Regards,Jitenkumar
Unable to attach form here so sharing a pic
 Form - Form_Imate_Creator_FB
Private Sub UserForm_Initialize()
    PopCoB_ElmtType
    CoB_ElmtType.ListIndex = 0
End Sub
Private Sub PopCoB_ElmtType()
    CoB_ElmtType.Clear
    'Initialise Raw Material Form Combo Box
    CoB_ElmtType.AddItem "8 Port Block"
    CoB_ElmtType.AddItem "4 Port Block"
    CoB_ElmtType.AddItem "M12 5Pin Conn Male"
    CoB_ElmtType.AddItem "M12 4Pin Conn Male"
    CoB_ElmtType.AddItem "M12 4Pin Conn Female"
    CoB_ElmtType.AddItem "M12 5Pin Conn Female"
End Sub
Private Sub CoBu_Exit_Click()
    FBiMC.Kill = True
    Unload Me
End Sub
Private Sub CoBu_Apply_Click()
    FBiMC.ElmtType = CoB_ElmtType.Value
    Unload Me
End Sub
Main Module
Public Type FBiMCObj_Datatype 'used in Cls_GetSelObj_FB as well hence public
    IMObject As Object
    IMBiasPoint As Point
End Type
Public Type FBiMC_DataType
    Doc As Document
    ElmtType As String
    Kill As Boolean
    Esc As Boolean
End Type
Public FBiMC As FBiMC_DataType
Dim N_iports As Integer
Sub Imate_Creator_FB()
    Set FBiMC.Doc = ThisApplication.ActiveDocument
    If FBiMC.Doc.DocumentType = kPartDocumentObject Xor kAssemblyDocumentObject Then
            'Pass
        Else
            MsgBox "File Type Not Compatible. Please Use a Part or an Assembly File"
            Exit Sub
    End If
    FBiMC.Kill = False
    FBiMC.Esc = False
    Form_Imate_Creator_FB.Show
    If FBiMC.Kill Then Exit Sub ' just to cut short the calculation time. Create_iMate any way terminates on FBiMC.Kill
    CreateiMates FBiMC.Doc, FBiMC.ElmtType
End Sub
Sub CreateiMates(ByRef sDoc As Document, ByVal sElmtType As String)
    Dim Compdef As ComponentDefinition
    Dim iMateColl As ObjectCollection
    Dim CiMateMatchList() As String
    Dim Offset As String
    Dim mate As iMateDefinition
    Dim CMate As CompositeiMateDefinition
    Dim a As Integer
    Set Compdef = sDoc.ComponentDefinition
    Select Case FBiMC.ElmtType
        Case "8 Port Block": N_iports = 8
        Case "4 Port Block": N_iports = 4
    End Select
    Set iMateColl = ThisApplication.TransientObjects.CreateObjectCollection
    Case "8 Port Block", "4 Port Block"
        Set mate = Create_iMate(sDoc, sElmtType, "Port-A M12 6P Male", "M12 6P Insert", "Insert", "0 in", True)
        If FBiMC.Kill = False Then iMateColl.Add mate Else Exit Sub
        Set mate = Create_iMate(sDoc, sElmtType, "Port-A M12 6P Male", "M12 6P Orientation", "Angle", "180 deg", True)
        CiMateMatchList = Create_CiMatchList("Port-A M12 6P Male", sElmtType)
        'Debug.Print UBound(CiMateMatchList, 1) & CiMateMatchList(0)
        If IsArrayInitialized(CiMateMatchList) Then
            Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Male", CiMateMatchList)
        Else
            Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Male")
        End If
        iMateColl.Clear
        Set mate = Create_iMate(sDoc, sElmtType, "Port-B M12 6P Female", "M12 6P Insert", "Insert", "0 in", True)
        Set mate = Create_iMate(sDoc, sElmtType, "Port-B M12 6P Female", "M12 6P Orientation", "Angle", "180 deg", True)
        CiMateMatchList = Create_CiMatchList("Port-A M12 6P Female", sElmtType)
            Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Female", CiMateMatchList)
        Else
            Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-A M12 6P Female")
        End If
        iMateColl.Clear
        For a = 0 To N_iports - 1
            iMateColl.Clear
            Set mate = Create_iMate(sDoc, sElmtType, "Port-" & a & " M12 5P Female", "M12 4P/5P Insert", "Insert", "0.001 in", True)
            Set mate = Create_iMate(sDoc, sElmtType, "Port-" & a & " M12 5P Female", "M12 4P/5P Orientation", "Angle", "180 deg", True)
            CiMateMatchList = Create_CiMatchList("Port-" & a & " M12 5P Female", sElmtType)
                Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-" & a & " M12 5P Female", CiMateMatchList)
            Else
                Set CMate = Compdef.iMateDefinitions.AddCompositeiMateDefinition(iMateColl, "Port-" & a & " M12 5P Female")
            End If
        Next a
    End Select
End Sub
Function Create_CiMatchList(ByVal f_CiMateName, f_ElmtType As String) As String()
Dim MatchList() As String
Dim a As Integer
Erase MatchList
Select Case f_ElmtType
    Select Case f_CiMateName
    Case "Port-A M12 6P Male"
        ReDim MatchList(0)
        MatchList(0) = "M12 6P Female"
    Case "Port-B M12 6P Female"
        ReDim MatchList(0)
        MatchList(0) = "M12 6P Male"
    End Select
        If f_CiMateName = "Port-" & a & " M12 6P Female" Then
            ReDim MatchList(1)
            MatchList(0) = "M12 4P Male"
            MatchList(1) = "M12 5P Male"
        End If
    Next a
Case Else
End Select
Create_CiMatchList = MatchList
End Function
Function Create_MatchList(ByVal f_CiMateName, f_iMateName, f_ElmtType As String) As String()
Dim a As Integer
Erase MatchList
        Select Case f_iMateName
        Case "M12 6P Insert"
            ReDim MatchList(0)
            MatchList(0) = "M12 6P Female Insert"
        Case "M12 6P Orientation"
            ReDim MatchList(0)
            MatchList(0) = "M12 6P Female Orientation"
        Case Else
        End Select
            ReDim MatchList(0)
            MatchList(0) = "M12 6P Male Insert"
            ReDim MatchList(0)
            MatchList(0) = "M12 6P Male Orientation"
        Case Else
        End Select
    End Select
        If f_CiMateName = "Port-" & a & " M12 5P Female" Then
            Case "M12 4P/5P Insert"
                ReDim MatchList(1)
                MatchList(0) = "M12 4P Male Insert"
                MatchList(1) = "M12 5P Male Insert"
            Case "M12 4P/5P Orientation"
                ReDim MatchList(1)
                MatchList(0) = "M12 4P Male Orientation"
                MatchList(1) = "M12 5P Male Orientation"
            Case Else
            End Select
        End If
    Next a
Case "M12 6Pin Conn"
    Case "M12 6P Male"
            ReDim MatchList(2)
            MatchList(0) = "Port-A M12 6P Female Insert"
            MatchList(1) = "Port-B M12 6P Female Insert"
            MatchList(2) = "M12 6P Female Insert"
            ReDim MatchList(2)
            MatchList(0) = "Port-A M12 6P Female Orientation"
            MatchList(1) = "Port-B M12 6P Female Orientation"
            MatchList(2) = "M12 6P Female Orientation"
        Case Else
        End Select
    Case "M12 6P Female"
            ReDim MatchList(2)
            MatchList(0) = "Port-A M12 6P Male Insert"
            MatchList(1) = "Port-B M12 6P Male Insert"
            MatchList(2) = "M12 6P Male Insert"
            ReDim MatchList(2)
            MatchList(0) = "Port-A M12 6P Male Orientation"
            MatchList(1) = "Port-B M12 6P Male Orientation"
            MatchList(2) = "M12 6P Male Orientation"
        Case Else
        End Select
    Case Else
    End Select
Case "M12 5Pin Conn"
    Case "M12 5P Male"
            ReDim MatchList(8)
            MatchList(0) = "Port-0 M12 5P Female Insert"
            MatchList(1) = "Port-1 M12 5P Female Insert"
            MatchList(2) = "Port-2 M12 5P Female Insert"
            MatchList(3) = "Port-3 M12 5P Female Insert"
            MatchList(4) = "Port-4 M12 5P Female Insert"
            MatchList(5) = "Port-5 M12 5P Female Insert"
            MatchList(6) = "Port-6 M12 5P Female Insert"
            MatchList(7) = "Port-7 M12 5P Female Insert"
            MatchList(8) = "M12 5P Female Insert"
        Case "M12 5P Orientation"
            ReDim MatchList(8)
            MatchList(0) = "Port-0 M12 5P Female Orientation"
            MatchList(1) = "Port-1 M12 5P Female Orientation"
            MatchList(2) = "Port-2 M12 5P Female Orientation"
            MatchList(3) = "Port-3 M12 5P Female Orientation"
            MatchList(4) = "Port-4 M12 5P Female Orientation"
            MatchList(5) = "Port-5 M12 5P Female Orientation"
            MatchList(6) = "Port-6 M12 5P Female Orientation"
            MatchList(7) = "Port-7 M12 5P Female Orientation"
            MatchList(8) = "M12 5P Female Orientation"
        Case Else
        End Select
    Case "M12 5P Female"
            ReDim MatchList(8)
            MatchList(0) = "Port-0 M12 5P Male Insert"
            MatchList(1) = "Port-1 M12 5P Male Insert"
            MatchList(2) = "Port-2 M12 5P Male Insert"
            MatchList(3) = "Port-3 M12 5P Male Insert"
            MatchList(4) = "Port-4 M12 5P Male Insert"
            MatchList(5) = "Port-5 M12 5P Male Insert"
            MatchList(6) = "Port-6 M12 5P Male Insert"
            MatchList(7) = "Port-7 M12 5P Male Insert"
            MatchList(8) = "M12 5P Male Insert"
            ReDim MatchList(8)
            MatchList(0) = "Port-0 M12 5P Male Orientation"
            MatchList(1) = "Port-1 M12 5P Male Orientation"
            MatchList(2) = "Port-2 M12 5P Male Orientation"
            MatchList(3) = "Port-3 M12 5P Male Orientation"
            MatchList(4) = "Port-4 M12 5P Male Orientation"
            MatchList(5) = "Port-5 M12 5P Male Orientation"
            MatchList(6) = "Port-6 M12 5P Male Orientation"
            MatchList(7) = "Port-7 M12 5P Male Orientation"
            MatchList(8) = "M12 5P Male Orientation"
        Case Else
        End Select
    Case Else
    End Select
Case "M12 4Pin Conn"
    Case "M12 4P Male"
            ReDim MatchList(9)
            MatchList(8) = "M12 4P Female Insert"
            MatchList(9) = "M12 5P Female Insert"
            ReDim MatchList(9)
            MatchList(8) = "M12 4P Female Orientation"
            MatchList(9) = "M12 5P Female Orientation"
        Case Else
        End Select
    Case "M12 4P Female"
            ReDim MatchList(9)
            MatchList(8) = "M12 4P Male Insert"
            MatchList(9) = "M12 5P Male Insert"
            ReDim MatchList(9)
            MatchList(8) = "M12 4P Male Orientation"
            MatchList(9) = "M12 5P Male Orientation"
        Case Else
        End Select
    Case Else
    End Select
Case Else
End Select
Create_MatchList = MatchList
End Function
's_Direction works only when Insert, Tangent and Angle mates
Function Create_iMate(ByRef s_Doc As Document, ByVal s_ElmtType As String, ByVal s_CiMateName, s_iMateName, s_iMateType, s_Offset As String, ByVal s_Direction As Boolean) As iMateDefinition
    Dim oPCompDef As PartComponentDefinition
    Dim oACompDef As AssemblyComponentDefinition
    Dim sObjData As FBiMCObj_Datatype
    Dim No_sObjData As FBiMCObj_Datatype
    Dim nBiasPoint As Point
    Dim nObject As Object
    Dim nface As Face
    Dim nAxis As Axis
    Dim nEdge As Object
    Dim niMateSuccess As Boolean
    Dim oselectedobject As New Cls_GetSelObj_FB
    Dim oMateiMateDefinition As MateiMateDefinition
    Dim oInsertiMateDefinition As InsertiMateDefinition
    Dim oFlushiMateDefinition As FlushiMateDefinition
    Dim oTangentiMateDefinition As TangentiMateDefinition
    Dim oAngleiMateDefinition As AngleiMateDefinition
    Dim oiMateMatchList() As String
    If FBiMC.Kill Then Exit Function
    If s_Doc.DocumentType = kPartDocumentObject Then Set oPCompDef = s_Doc.ComponentDefinition
    If s_Doc.DocumentType = kAssemblyDocumentObject Then Set oACompDef = s_Doc.ComponentDefinition
    oiMateMatchList = Create_MatchList(s_CiMateName, s_iMateName, s_ElmtType)
    Select Case s_iMateType
    Case "Mate":
        niMateSuccess = False: FBiMC.Esc = False
        Do
            If FBiMC.Esc Or FBiMC.Kill Then Exit Do
            On Error Resume Next
                sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Planar Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType)
                Set nObject = sObjData.IMObject
                Set nBiasPoint = sObjData.IMBiasPoint
'                Select Case nObject.Type
'                    Case kEdgeProxyObject, kEdgeObject
'                    Case Else
'                        Dim dCurrent(2) As Double
'                        Dim adEye(2) As Double
'                        adEye(0) = 0
'                        adEye(1) = 0
'                        adEye(2) = 0
'                        Dim adGuessparams() As Double
'                        Dim adMaxDeviations() As Double
'                        Dim adParams(1) As Double
'                        Dim aenSolTypes() As SolutionNatureEnum
'                        Call nObject.Evaluator.GetParamAtPoint(adEye, adGuessparams, adMaxDeviations, adParams, aenSolTypes)
'                        If err Then MsgBox err.Description
'                        MsgBox adParams(0) & "," & adParams(1) & "-" & aenSolTypes(0)
'                        Call nObject.Evaluator.GetPointAtParam(adParams, dCurrent)
'                        MsgBox nBiasPoint.X & "," & nBiasPoint.Y & "," & nBiasPoint.Z & vbCrLf & dCurrent(0) & "," & dCurrent(1) & "," & dCurrent(2)
'                        nBiasPoint.X = nBiasPoint.X - dCurrent(0)
'                        nBiasPoint.Y = nBiasPoint.Y - dCurrent(1)
'                        nBiasPoint.Z = nBiasPoint.Z - dCurrent(2)
'                End Select
                If Err Then MsgBox Err.Description & ":Probably Object or Bias Point not selected", vbCritical, Err.Number & ":" & s_iMateName: Exit Function
            On Error GoTo 0
        'Set nface = ThisApplication.CommandManager.Pick(kPartFacePlanarFilter, s_iMateName & ":Select a Planar Face.")
            If Not nObject Is Nothing Then
                    Case kFaceProxyObject, kFaceObject, kWorkPlaneProxyObject, kWorkPlaneObject
                        Select Case s_Doc.DocumentType
                            Case kPartDocumentObject:
                                If IsArrayInitialized(oiMateMatchList) Then
                                    Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , nBiasPoint, s_iMateName, oiMateMatchList)
                                Else
                                    Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , nBiasPoint, s_iMateName)
                                End If
                            Case kAssemblyDocumentObject:
                                    Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , , s_iMateName, oiMateMatchList)
                                Else
                                    Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, , , s_iMateName)
                                End If
                        End Select
                        niMateSuccess = True
                    Case Else: MsgBox " Selected Feature failed for selected imate", vbCritical, s_iMateName
                End Select
            End If
        Loop While niMateSuccess = False
        sObjData = No_sObjData
        Set Create_iMate = oMateiMateDefinition
    Case "Axis":
        Do
                sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Cylindrical Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType)
            On Error GoTo 0
                        If nObject.SurfaceType = kCylinderSurface Or nObject.SurfaceType = kConeSurface Then
                                        Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName, oiMateMatchList)
                                    Else
                                        Set oMateiMateDefinition = oPCompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName)
                                    End If
                                        Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName, oiMateMatchList)
                                    Else
                                        Set oMateiMateDefinition = oACompDef.iMateDefinitions.AddMateiMateDefinition(nObject, s_Offset, kInferredLine, , s_iMateName)
                                    End If
                            End Select
                        Else: MsgBox "Selected Feature not a cylinderical face", vbCritical, s_iMateName
                        End If
                End Select
            End If
    Case "Flush"
        Do
            On Error GoTo 0
                                    Set oFlushiMateDefinition = oPCompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName, oiMateMatchList)
                                Else
                                    Set oFlushiMateDefinition = oPCompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName)
                                End If
                                    Set oFlushiMateDefinition = oACompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName, oiMateMatchList)
                                Else
                                    Set oFlushiMateDefinition = oACompDef.iMateDefinitions.AddFlushiMateDefinition(nObject, s_Offset, , s_iMateName)
                                End If
                        End Select
                End Select
            End If
        Set Create_iMate = oFlushiMateDefinition
    Case "Insert":
        Do
                sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select Circular Edge or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType)
            On Error GoTo 0
                    Select Case nObject.GeometryType
                    Case kCircleCurve, kCircularArcCurve
                                Set oInsertiMateDefinition = oPCompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList)
                            Else
                                Set oInsertiMateDefinition = oPCompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName)
                            End If
                                Set oInsertiMateDefinition = oACompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList)
                            Else
                                Set oInsertiMateDefinition = oACompDef.iMateDefinitions.AddInsertiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName)
                            End If
                        End Select
                    Case Else: MsgBox " Selected Feature not a Circular edge", vbCritical, s_iMateName
                    End Select
                Case Else: MsgBox " Selected Feature not an edge", vbCritical, s_iMateName
                End Select
            End If
        Set Create_iMate = oInsertiMateDefinition
    Case "Tangent":
        Do
                If FBiMC.ElmtType <> Fitting Then
                Else
                    sObjData = oselectedobject.Get_SObject(s_Doc, s_CiMateName & ">" & s_iMateName & ": Select a Face or Press 'Q' for options,'Esc' to Abort", s_iMateType, FBiMC.ElmtType)
                End If
            On Error GoTo 0
                    If FBiMC.ElmtType <> "Fitting" Then
                        If nObject.SurfaceType = kCylinderSurface Then
                            If Not IsCylindricalFaceInterior(nObject) Then
                                            Set oTangentiMateDefinition = oPCompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList)
                                        Else
                                            Set oTangentiMateDefinition = oPCompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName)
                                        End If
                                            Set oTangentiMateDefinition = oACompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList)
                                        Else
                                            Set oTangentiMateDefinition = oACompDef.iMateDefinitions.AddTangentiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName)
                                        End If
                                End Select
                            Else: MsgBox "Selected Feature not an External cylinderical face", vbCritical
                            End If
                        End If
                    Else
                                Else
                                End If
                                Else
                                End If
                        End Select
                    End If
                Case Else: MsgBox " Selected Feature is not a face", vbCritical, s_iMateName
                End Select
            End If
        Set Create_iMate = oTangentiMateDefinition
    Case "Angle"
        Do
            On Error GoTo 0
                Case kFaceProxyObject, kFaceObject, kWorkPlaneProxyObject, kWorkPlaneObject ' needs to be tested thoroughly
                            Set oAngleiMateDefinition = oPCompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList)
                        Else
                            Set oAngleiMateDefinition = oPCompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName)
                        End If
                            Set oAngleiMateDefinition = oACompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName, oiMateMatchList)
                        Else
                            Set oAngleiMateDefinition = oACompDef.iMateDefinitions.AddAngleiMateDefinition(nObject, s_Direction, s_Offset, , s_iMateName)
                        End If
                    End Select
                End Select
            End If
        Set Create_iMate = oAngleiMateDefinition
    End Select
End Function
Function IsArrayInitialized(a) As Boolean
    Dim i As Integer
    Err.Clear
    i = UBound(a)
    If (Err.Number = 0) Then
        IsArrayInitialized = True
    Else
        IsArrayInitialized = False
    End If
    On Error GoTo 0
End Function
Function IsCylindricalFaceInterior(ByVal oFace As Face) As Boolean
    If Not oFace.SurfaceType = kCylinderSurface Then
        MsgBox "A cylindrical face must be selected."
        Exit Function
    End If
    Dim oCylinder As Cylinder
    Set oCylinder = oFace.Geometry
    Dim params(1) As Double
    params(0) = 0.5
    params(1) = 0.5
    ' Get point on surface at param .5,.5
    Dim points(2) As Double
    Call oFace.Evaluator.GetPointAtParam(params, points)
    ' Create point object
    Dim oPoint As Point
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint(points(0), points(1), points(2))
    ' Get normal at this point
    Dim normals(2) As Double
    Call oFace.Evaluator.GetNormal(params, normals)
    ' Create normal vector object
    Dim oNormal As Vector
    Set oNormal = ThisApplication.TransientGeometry.CreateVector(normals(0), normals(1), normals(2))
    ' Scale vector by radius of the cylinder
    oNormal.ScaleBy oCylinder.Radius
    ' Find the sampler point on the normal by adding the
    ' scaled normal vector to the point at .5,.5 param.
    Dim oSamplePoint As Point
    Set oSamplePoint = oPoint
    oSamplePoint.TranslateBy oNormal
    ' Check if the sample point lies on the cylinder axis.
    ' If it does, we have a hollow face.
    ' Create a line describing the cylinder axis
    Dim oAxisLine As Line
    Set oAxisLine = ThisApplication.TransientGeometry.CreateLine(oCylinder.BasePoint, oCylinder.AxisVector.AsVector)
    'Create a line parallel to the axis passing thru the sample point.
    Dim oSampleLine As Line
    Set oSampleLine = ThisApplication.TransientGeometry.CreateLine(oSamplePoint, oCylinder.AxisVector.AsVector)
    If oSampleLine.IsColinearTo(oAxisLine) Then
        'MsgBox "Interior face."
        IsCylindricalFaceInterior = True
    Else
        'MsgBox "Exterior face."
        IsCylindricalFaceInterior = False
    End If
End Function
Class Module - Cls_GetSelObj_FB
'Public Variables used -
'Imate_Creator_Pn :- FBiMC.Kill,FBiMC.Esc
'-----------------------XXXXXXXX-----------------
'References Used -
'Imate_Creator_Pn :- FBiMCObj_Datatype
'Referenced by -
'Imate_Creator_Pn
'Form_Imate_Creator_Pn
Private WithEvents oInteractionEvents As InteractionEvents
Private WithEvents i_MouseEvents As MouseEvents
Private WithEvents i_SelectEvents As SelectEvents
Private WithEvents i_KeyboardEvents As KeyboardEvents
Private WithEvents uiEvents As UserInputEvents
Private bStillSelecting As Boolean
Private iObject As Object
Private iPoint As Point
Private iFace, iOFace As Face
Private iAxis As Axis
Private iEdge, iOEdge As Edge
Public Function GetFace(ByVal f_Doc As Document, f_Status As String) As Face
    f_Doc.SelectSet.Clear
    ' Create interaction events
    Set oInteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents
    oInteractionEvents.StatusBarText = f_Status
    Set i_KeyboardEvents = oInteractionEvents.KeyboardEvents
    Set i_MouseEvents = oInteractionEvents.MouseEvents
    Set i_SelectEvents = oInteractionEvents.SelectEvents
    i_SelectEvents.ResetSelections
    i_SelectEvents.ClearSelectionFilter
    i_SelectEvents.SingleSelectEnabled = True
    i_SelectEvents.Enabled = True
    i_SelectEvents.AddSelectionFilter kPartFacePlanarFilter
    i_SelectEvents.AddSelectionFilter kWorkPlaneFilter
    bStillSelecting = True
    oInteractionEvents.Start
    Do While bStillSelecting
        DoEvents
    Loop
    Set GetFace = iFace
End Function
Public Function GetOFace(ByVal f_Doc As Document, f_Status As String) As Face
    i_SelectEvents.AddSelectionFilter kPartFaceCylindricalFilter
    i_SelectEvents.AddSelectionFilter kPartFaceConicalFilter
        DoEvents
    Loop
    Set GetOFace = iOFace
End Function
Public Function GetOEdge(ByVal f_Doc As Document, f_Status As String) As Edge
    i_SelectEvents.AddSelectionFilter kPartEdgeCircularFilter
        DoEvents
    Loop
    Set GetOEdge = iOEdge
End Function
'Public Function Get_Object(ByVal f_Doc As Document, ByVal f_Status, i_iMatetype As String) As Object ' WIP
Public Function Get_SObject(ByVal f_Doc As Document, ByVal f_Status, i_iMatetype, f_ElementType As String) As FBiMCObj_Datatype ' WIP
    FBiMC.Esc = False
    'oInteractionEvents.InteractionDisabled = False
    Select Case i_iMatetype
        Case "Mate", "Flush":
        Case "Angle":
        Case "Axis":
            i_SelectEvents.AddSelectionFilter kPartFaceCylindricalFilter ' To be changed here to Axis Selection Filter right now workaround is by selecting face
        Case "Tangent":
            If f_ElementType <> "Fitting" Then
                'i_SelectEvents.AddSelectionFilter kPartFaceConicalFilter
            Else
            End If
        Case "Insert": i_SelectEvents.AddSelectionFilter kPartEdgeCircularFilter
    End Select
        DoEvents
    Loop
    Set Get_SObject.IMObject = iObject
    Set Get_SObject.IMBiasPoint = iPoint 'Suppress in case function returns Object instead of FBiMCObj_Datatype
    'MsgBox Get_SObject.IMBiasPoint.X & "," & Get_SObject.IMBiasPoint.Y & "," & Get_SObject.IMBiasPoint.Z
End Function
Private Sub i_SelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
Set iPoint = ModelPosition
    Set iObject = i_SelectEvents.SelectedEntities(1)
    Set iFace = i_SelectEvents.SelectedEntities(1)
    Set iOFace = i_SelectEvents.SelectedEntities(1)
    Set iAxis = i_SelectEvents.SelectedEntities(1)
    'Set iEdge = i_Selectevents.SelectedEntities(1)
    Set iOEdge = i_SelectEvents.SelectedEntities(1)
On Error GoTo 0
bStillSelecting = False
End Sub
Private Sub i_MouseEvents_OnMouseClick(ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View)
End Sub
Private Sub i_KeyboardEvents_OnKeyPress(ByVal KeyAscii As Long)
    Dim i As Integer
    If KeyAscii = 113 Or KeyAscii = 81 Then ' Ascii Code for "q" and "Q"
        i = MsgBox("Do you want to escape creating this iMate", vbQuestion + vbDefaultButton2 + vbAbortRetryIgnore) 'Selecting no here does go back to control. needs to be sorted out.
        Select Case i
            Case 5: bStillSelecting = False: FBiMC.Esc = True
            Case 4: bStillSelecting = True
            Case 3: FBiMC.Kill = True: bStillSelecting = False
        End Select
    End If
End Sub
Private Sub oInteractionEvents_OnTerminate() ' on Keypress esc
    Dim i As Integer
    i = MsgBox("Terminating the Interaction Process", vbCritical + vbOKOnly) 'Option to return not working as selection filter fails here perhaps interaction event dies here
    Select Case i
        Case 1: FBiMC.Kill = True: bStillSelecting = False
    End Select
End Sub
Private Sub uiEvents_OnTerminateCommand(ByVal CommandName As String, ByVal Context As NameValueMap)
    Set uiEvents = Nothing
    Dim i As Integer
    i = MsgBox("Do you want to escape creating this iMate", vbQuestion + vbDefaultButton2 + vbAbortRetryIgnore, CommandName)
    Select Case i
    End Select
End Sub
Replies (0)
