How to get the same part number?
Dear All,
I met a problem, my stituation is:
I need create an assembly model with a sub-assemble model, what I want is use the same item number(same as the sub-assemble model) in the new model. For example, in sub-assemble B, the item number is part A--No.100, but in the new model, part A--No.2. Is it possible to unified the item number?
Thanks in advance for your great help!!!Smiley Happy
CCarreiras
Hi!
No. each main assembly has it own numbering.
You can edit this numbering, but will be a manual process.
CCarreiras
Hi Fiona,
With this code you can make all the item number to same value. Hope this helps you.
Sub Bom_Row()
Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
Dim oBomView As BOMView
    Set oBomView = oDoc.ComponentDefinition.BOM.BOMViews.Item("Parts Only")
Dim oBomRow As BOMRow
    For Each oBomRow In oBomView.BOMRows
        oBomRow.ItemNumber = "Part A--No 100"
    Next
End Sub
Dear SK.,
Thanks very much for your suggestion, but how to use this code? Can you help to point out?
THX.
GoTo Tools Tab --> Vba editor as show in the image
Now a new window will open in that create new module as described in the below image
Now copy and paste the code in that window and run it by pressing f5 key or run button
Thanks SK,
But somehow all the parts items are 100 now~~~It is ok, I will input manually.Smiley Happy
