Duplicate types in Inventor Namespace.
woodstylee3
Message 1 of 1
woodstylee3
All,
I have hit a weird bug in my code that only occours at runtime. I haven't posted too much code as the project is in a solution with a lot of code.
The if statement in my code..
Private Sub export_materials_rough_list_assy(componentdef As Inventor.ComponentDefinition, excelwks As Microsoft.Office.Interop.Excel.Worksheet, ByRef ctr As Integer, ByVal baseqty As Integer, ByVal parent As String)
If componentdef.Type = ObjectTypeEnum.kPartComponentDefinitionObject Then
bom = componentdef.BOMStructure
For Each bomv As Inventor.BOMView In componentdef.BOM.BOMViews
If bomv.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then
For Each bomrow As Inventor.BOMRow In bomv.BOMRows
Dim process As Boolean
Select Case bomrow.BOMStructure
Case Is = BOMStructureEnum.kVariesBOMStructure
process = True
throws an error ObjectTypeEnum.kPartComponentDefinitionObject is ambiguous in namespace inventor.
All the following lines and references to Inventor object model work correctly.
The same error gets thrown with
If componentdef.Type = Inventor.ObjectTypeEnum.kPartComponentDefinitionObject Then
Any suggestions as to where a duplicate name in the same namespace creeping in could be coming from would be appreciated.
Replies (0)
