How to get the area of a closed sketch in Inventor VBA
Hi
There is a closed sketch from a flat surface contour, how to get the area of this 2D sketch in Inventor VBA?
Thanks.
Presuming there is no voids inside the sketch this will show the last made
sketch's area in cm^
If there are more than one profile in the sketch you would have to loop
through each profile and somehow decide if it is excluded or not.
Public Sub SketchArea()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim oSketch As Sketch
Set oSketch = oCompDef.Sketches(oCompDef.Sketches.Count - 1)
Dim oProfile As Profile
Set oProfile = oSketch.Profiles(1)
Dim oArea As Double
oArea = oProfile.RegionProperties.Area
MsgBox "The area of the sketch is " & oArea & "cm^2"
End Sub
KWiKMcad
Kent Keller
"allenliuyy" wrote in message news:6325084@discussion.autodesk.com...
Hi
Thanks.
Thank you, Kent. It works.
If there are 5 sketches called "sketch1", "sketch2", ...."sketch5" in one part, how to get all these sketches area one by one. I tried the similar way, but I could not figure it out. Thanks again.
Try something along the lines of
For each oSketch in oCompDef.sketches
"Process sketch
Next
KWiKMcad
Kent Keller
"allenliuyy" wrote in message news:6326033@discussion.autodesk.com...
