How to get rid of units
With MDT it is possible to derive component properties through manipulation
of the model parameters in the part-file with formulas in the BOM. For a
custom U-profile it would look like this:
BOM
Component
Formula
Property
=IF(ISBLANK(PART:NAME),BLOCK:NAME,PART:NAME) W208
=U - xxx
U - 40x60x40x2
250
= 208
=Zie: .dxf
Zie: W208.dxf
These resulting properties finaly end up in a part list:
| U - 40x60x40x2 | 250 | Zie: W208.dxf |
With iProperty Expressions in IV2009 the best I can get in the partlist is:
| U - 40 mmx60 mmx40 mmx2 mm | 250 mm | Zie: W208.dxf |
How can I get rid of the units en their adjacent space character? How to
manipulate these strings? Any help would be fine.
h.rosbergenNOSP@Moctatube.nl
<< - omit capitals - >>
what version of Inventor are you using? With 2009 you can set custom property formatting to omit units.
Please reveal where I can find that option?
wrote in message news:5912469@discussion.autodesk.com...
I don't know about thru customization, I couldn't find any API calls. But if you open your part in Inventor, go to the parameter table, then RMB on the Equation cell for a parameter that is exported, a menu will appear that has "Custom Property Format". Click the button and a custom property format dialog will appear, allowing you to control the format of the parameter.
For some reason it is well hidden, but it works for me.
Thanksalot
wrote in message news:5912505@discussion.autodesk.com...
