Fit parts list columns macro
Tired of having to manually resize your parts list columns? Wish that ADSK would implement an auto-fit, but can't wait for it to be added? Then try this handy dandy macro! (Use at your own risk, side effects may include giddiness, more free time, and uncontrollable urge to hug your computer)
Public Function PartsListFitColumns(oPartsList As PartsList) As PartsList
If oPartsList Is Nothing Then Exit Function
' get font info
Dim dWidth As Double
dWidth = oPartsList.DataTextStyle.FontSize * oPartsList.DataTextStyle.WidthScale
' find longest string in each column and resize column
Dim oRow As PartsListRow
Dim sData As String
Dim iCol As Integer
Dim iCols As Integer
iCols = oPartsList.PartsListColumns.Count
' set up array to hold column widths
Dim iLen() As Integer
ReDim iLen(iCols)
' initialize to header lengths
For iCol = 1 To iCols
iLen(iCol) = Len(oPartsList.PartsListColumns(iCol).Title)
Next iCol
' loop thru each row
For Each oRow In oPartsList.PartsListRows
If oRow.visible = True Then
sData = oRow.Item(iCol).Value ' get the data from the cell
If Len(sData) > iLen(iCol) Then
iLen(iCol) = Len(sData)
Next iCol
Next oRow
' resize the columns (note add extra 2 character width for padding)
oPartsList.PartsListColumns(iCol).Width = dWidth * (iLen(iCol) + 2)
Next iCol
Set PartsListFitColumns = oPartsList
End Function
Here is a simple way to use the macro, just select a parts list and then run the Sub below
(ALSO, this works best if you are using a monospace font, I don't know how it will work for a variable width font)
Public Sub PartsListSelectedFitColumns()
Dim oPartsList As PartsList
Set oPartsList = GetSelectedPartsList
If oPartsList Is Nothing Then Exit Sub
PartsListFitColumns oPartsList
End Sub
Public Function GetSelectedPartsList() As PartsList
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = GetActiveDrawing
If oDrawDoc Is Nothing Then Exit Function
Dim oSelectSet As SelectSet
Set oSelectSet = oDrawDoc.SelectSet
If oSelectSet.Count = 0 Then Exit Function
If oSelectSet.Item(1).Type <> kPartsListObject Then Exit Function
Set GetSelectedPartsList = oSelectSet.Item(1)
End Function
Public Function GetActiveDrawing() As DrawingDocument
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Set GetActiveDrawing = ThisApplication.ActiveDocument
Else
MsgBox "Must have a drawing active", vbOKOnly, "Error"
End Function
