How to get # Of Places on drawing dimension from part
nathan.quilla
nathan.quilla
Is there a way to pull the number of fillets or chamfers from the model properties into the dimension in the drawing?
A.Acheson
Hi @nathan.quilla
Here is likely what your looking for EdgeSetCount
Syntax
FilletDefinition.EdgeSetCount() As Long
Here is VBA sample for studying.
And here is an ilogic sample untested.
    ' Set a reference to the compdef.
    Dim compDef As PartComponentDefinition = ThisDoc.Document.ComponentDefinition
    ' Obtain a FilletDefinition object to use in defining the various inputs to create the fillet.
    Dim filletDef As FilletDefinition = compDef.Features.FilletFeatures.CreateFilletDefinition
    Dim count as Integer = filletDef.EdgeSetCount
    MessageBox.Show(count)
Actually picking up the drawing curve and checking what feature created it will be another layer of complexity.
Regards
Alan
nathan.quilla
Awesome, thank you for the help!
