How to force load all dependents in a drawing file
I have the following use case scenario
1) There is a Inventor drawing , which refers to two different parts
2) All the parts and drawing are stored locally on the disk
3) One of the part is modified on the disk
When I open the Inventor drawing
- Inventor fully loads the modified part in the session
- the second part(unmodified one) is not fully loaded
How can I force Inventor to fully load all dependents irrespective of their last saved state
is there any api/setting/preference that I can use
regards
I have verified using various options
but none works
  1. I have an Inventor Drawing  A.idw which refers a part B.ipt
  2. When I open the drawing normally and see the document loaded count, it shows as “1” ( expected )
  3. there was a suggestion to use "OpenWithOptions" with option FastOpen=False
  4. When I open the drawing using openwithoptions and see the document loaded count, it still shows as “1” ( expected count was 2)
Attached is the VBA macro snippet for your reference
-------CODE-BEGIN--------------------------
Sub ForceOpenDrawingWithDependents()
Dim docs As Documents
Set docs = ThisApplication.Documents
If Not IsNull(docs) Then
    Dim ops As NameValueMap
    Set ops = ThisApplication.TransientObjects.CreateNameValueMap
    ops.Add "FastOpen", False
    Dim doc As Document
    Set doc = docs.OpenWithOptions("D:\Data_Set\Inventor_2015\A.idw", ops)
    Debug.Print doc.FullDocumentName
    Debug.Print "Loaded Doc Count: "; docs.LoadedCount
    Debug.Print "Total Doc Count: "; docs.Count
End If
End Sub
-------CODE-END--------------------------
