How to do API access to the Styles Library in IV10 and/or up?
for some reason I want to access the Styles Library (read access, maybe write later).
I like to query some things like Layers for drawings, Parts Lists, Materials etc.
Some of these things that are locally stored in some types of documents are available through that specific document-object (I haven't done this yet but I have seen the objects in the API).
But how do I access the Styles Library?
Has anyone a little help...
CU,
Guido
The various styles collections under DrawingDocument.StylesManager provides
a composite view of styles in the document as well as in the library. In
Inventor 2008, you will find a DrawingStylesManager.Styles property that
returns all the styles. The Style.StyleLocation property indicates whether
the style is local to the document, is in the library or both.
Sanjay-
wrote in message news:5683631@discussion.autodesk.com...
write later).
etc.
CU,
Guido
thanks a lot! I'll try it out...
By,
Guido
