ProcessViewSelection
Message 1 of 10
Could anybody give me an example on how to use ProcessViewSelection?
I have the GenericObject from a selectset, but I'm stuck on how to get further...
In my SelectSet is a GenericObject, resulting form selecting a part in a view (part priority). This view contains an assembly and I want to get the filename/fileObject of the selected part.
Hope this made sense to some of you 🙂
Ronny
Replies (9)
Message 2 of 10
I've attached some code to demonstrate. The returned oSelectedObj in your
case should be a ComponentOccurrence object in the context of the top level
assembly. ComponentOccurrence.Definition.Document returns the Part document
of interest.
Sanjay-
Sub ProcessSelection()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oGenObj As GenericObject
Set oGenObj = oDoc.SelectSet(1)
Dim oView As DrawingView
Dim oSelectedObj As Object
Call oDoc.ProcessViewSelection(oGenObj, oView, oSelectedObj)
End Sub
wrote in message news:5683802@discussion.autodesk.com...
further...
Ronny
Message 3 of 10
rschader
Perhaps this code snippet I used will help you:
' if we get a IRxGenericObject, see what other kind of info we can get.
If TypeName(oMyEnt1) = "IRxGenericObject" Then
Dim oDrawView As DrawingView
Dim gObject As Object
' can we assume that we have a drawingdocument if we get a generic object?
' let's find out.
oDoc.ProcessViewSelection oMyEnt1, oDrawView, gObject
MsgBox "Generic Object Type: " & TypeName(gObject)
'IRxComponentOccurence + IRxComponentOccurenceProxy ok
'IRxRevolveFeature good.
'IRxChamferFeature good.
'IRxExtrudeFeature good.
'IRxNonParametricBaseFeature good.
'IRxHoleFeature ok
'IRxShellFeature ok
'IRxFilletFeature ok
'IRxSplitFeature ok
'IRxSweepFeature ok
'WorkPoints/axes choke at assigning the selectset.
The comment lines show what I had tested and was able to get results for or not. ALot of these objects are returned as their native (non generic) in IV2008. Which version are you using?
Bob S.
Message 4 of 10
OK, so I need to do some more checking than just to assume this is a part.
Yes, I use IV2008 SP1 (of course??? ;-)).
Just a thought:
If I first check to see if the selection filter is set to part priority, can I then assume it is a part in the SelectSet? (If I actually can check this...)
Message 5 of 10
Thank you Sanjay, this worked just fine.
The API-help could have been a bit more descriptive, if it had said that the method will return the View and the selected object I probably would figure out this myself...
The API-help should have more detailed descriptions and examples of how to use the different methods and functions...
Ronny
Message 6 of 10
This code you provided works fine, but not completely...
If the selectset contains a section line, this fails.
How can i check if the selection is a section line? I have made som debugging code like this:
oGeneric = oSelectset(1)
Dim test = TypeName(oGeneric)
If I select a part, test="IRxGenericObject"
and if I select a section line, test="IRxGenericObject"
So I can not check whether oGeneric is of type "IRxGenericObject".
How can I decide if my selection is a section line?
Ronny
Reply From: Sanjay Ramaswamy \(Autodesk\)
Date: Aug/08/07 - 20:12 (CEST)
Re: ProcessViewSelection
of interest.
Sanjay-
End Sub
Message 7 of 10
Unfortunately, there isn't an API object that represents a section line. So
there isn't a way to determine if the selected object is a section line.
Sorry.
Sanjay-
wrote in message news:5701036@discussion.autodesk.com...
Ronny
of interest.
Sanjay-
End Sub
Message 8 of 10
OK, I can get around it with a try...catch...end try, with no code in the catch "area", but it is not very elegant... Perhaps in the future??
Thanks anyway.
Ronny
Message 9 of 10
Sanjay,
Digging up an old post, but...
The code here works well for features in sheet metal formed views, but returns a part document when selecting with feature priority into a flat view. Is there a way to access sheet metal features selected in the flat view? Is IV2010 better here than IV2009? Will addins do what VBA cannot? The goal is to automate callout of punch tool features in a way that the 2009 annotion won't do.
Brian.
Message 10 of 10
Yes, things should work better in Inventor 2010.
The features within a flat pattern were not exposed via the API prior to
Inventor 2010.
Sanjay-
