How to delete specific OLE (3rd Party) object using Ilogic.
caroline_ccc
caroline_ccc
Hello. I would like your help .
How to delete only one specific OLE reference from an IPT file?
It has 2  3rd Party  PDF reference and want to delete only one.
I`m using below code, but it deletes all files.  but I want to delete only item (A.pdf)
Dim oDoc As Inventor.Document
 Dim ref As Inventor.ReferencedOLEFileDescriptor
 oDoc = ThisApplication.ActiveDocument
 For Each ref In oDoc.ReferencedOLEFileDescriptors
    ref.Delete 'delete reference
 Next
JelteDeJong
does this work for you?
For Each ref As ReferencedOLEFileDescriptor In oDoc.ReferencedOLEFileDescriptors
    If (ref.DisplayName = "A.pdf") Then
        ref.Delete() 'delete reference
    End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
caroline_ccc
Many thanks @JelteDeJong.
It works perfectly. 🙂
I was trying to reference as Item(x) but it didn't work. With ref.DisplayName works well.
Appreciate your help!
