How to delete a drawing symbol from all the sheets in the drawing using VBA?
shuaib_cad
shuaib_cad
I want to delete a drawing symbol named "XXX" from all the sheets in the drawing but the symbol is getting deleted from the active sheet only.
Used the following VBA code:
Dim oSymbol As SketchedSymbol
For Each oSymbol In oDoc.ActiveSheet.SketchedSymbols
If oSymbol.Name = "XXX" Then
oSymbol.Delete
Please help me with a VBA code to do the operation in all the sheets in the drawing.
Mohammed Shuaib K
JhoelForshav
Hi @shuaib_cad
In order to do this you must iterate through each sheet in the drawing document 🙂
Sub DeleteSymbols()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    For Each oSymbol In oSheet.SketchedSymbols
    If oSymbol.Name = "XXX" Then oSymbol.Delete
    Next
Next
End Sub
