How to create various bodies at the same time
tiago.pereiraGB2J9
tiago.pereiraGB2J9
I am trying to create a lot of cylinders bodies in the same VBA code. I´ve found the sample code on AutoDesk site, but when I tried to create more than 1 solid body, it seems that create a surface body instead of solid. Does anyone have any idea about it? I´m attaching the VBA code and a picture of the output of my code.
Thanks so much!
Sub mymacro3()
    ' Create a new part document, using the default part template.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Set a reference to the component definition.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    ' Set a reference to the TransientBRep object.
    Dim oTransientBRep As TransientBRep
    Set oTransientBRep = ThisApplication.TransientBRep
    ' Create bottom and top points for the first cylinder.
    Dim oBottomPt As Point
    Set oBottomPt = ThisApplication.TransientGeometry.CreatePoint(0, 1, 0)
    Dim oTopPt As Point
    Set oTopPt = ThisApplication.TransientGeometry.CreatePoint(0, 3, 0)
	' Create bottom and top points for the second cylinder.
    Dim oBottomPt2 As Point
    Set oBottomPt2 = ThisApplication.TransientGeometry.CreatePoint(0, 5 ,0)
    Dim oTopPt2 As Point
    Set oTopPt2 = ThisApplication.TransientGeometry.CreatePoint(0, 7, 0)
    ' Create the cylinder body.
    Dim oCylinder As SurfaceBody
    Set oCylinder = oTransientBRep.CreateSolidCylinderCone(oBottomPt, oTopPt, 0.5, 0.5, 0.5)
    Dim oCylinder2 As SurfaceBody
    Set oCylinder2 = oTransientBRep.CreateSolidCylinderCone(oBottomPt2, oTopPt2, 0.5, 0.5, 0.5)
    ' Create a base feature with the result body.
    Dim oBaseFeature As NonParametricBaseFeature
    Set oBaseFeature = oCompDef.Features.NonParametricBaseFeatures.Add(oBody)
    Dim oBaseFeature2 As NonParametricBaseFeature
    Set oBaseFeature2 = oCompDef.Features.NonParametricBaseFeatures.Add(oCylinder)
End Sub
Curtis_Waguespack
Hi @tiago.pereiraGB2J9
Here is an iLogic version of this. Open a new part and paste this into a new iLogic rule and it will add 2 solid cylinders, but it joins them into a single solid. I'm not sure if that is acceptable for your purposes?
I hope this helps.
Curtis
oPartDoc = ThisDoc.Document
' a reference to the component definition.
' a reference to the TransientBRep object.
Dim oTopPt As Point
oBottomPt2 = ThisApplication.TransientGeometry.CreatePoint(0, 5, 0)
'join the 2 cylinders
Call oTransientBRep.DoBoolean(oCylinder, oCylinder2, BooleanTypeEnum.kBooleanTypeUnion)
oBaseFeature = oCompDef.Features.NonParametricBaseFeatures.Add(oCylinder)
tiago.pereiraGB2J9
Thanks so much for your reply @Curtis_Waguespack !
It works! Now I can create two solid bodies. But the ideal for me it´s to have different bodies. Telling you the main idea of the work is to build a hole model of an offshore platform, a frame structure. I was thinking about the problem in the last few days and building it with solid bodies doesn't seem to be the best way, because the model will be too large to work. Do you have any ideas for this?
Thanks again!
Curtis_Waguespack
Thanks again!
Hi @tiago.pereiraGB2J9 ,
I don't have any ideas on the offshore platform or if this is the best approach.
But I took another look at one of the other API examples and extracted what we needed to work with your original 2 cylinder example, this version creates 2 separate solids.
I hope this helps.
Curtis
Dim oTopPt As Point
Dim oCylinder1 As SurfaceBody
oCylinder1 = oTransientBRep.CreateSolidCylinderCone(oBottomPt, oTopPt, 0.5, 0.5, 0.5)
Dim nonParaDef As NonParametricBaseFeatureDefinition
nonParaDef = oCompDef.Features.NonParametricBaseFeatures.CreateDefinition
Dim bodyColl_1 As ObjectCollection
bodyColl_1 = ThisApplication.TransientObjects.CreateObjectCollection
Call bodyColl_1.Add(oCylinder1)
nonParaDef.BRepEntities = bodyColl_1
nonParaDef.OutputType = kSolidOutputType
Dim oBaseFeature1 As NonParametricBaseFeature
oBaseFeature1 = oCompDef.Features.NonParametricBaseFeatures.AddByDefinition(nonParaDef)
Try : oBaseFeature1.Name = "Base1" : Catch : End Try
Dim bodyColl_2 As ObjectCollection
bodyColl_2 = ThisApplication.TransientObjects.CreateObjectCollection
Call bodyColl_2.Add(oCylinder2)
nonParaDef.BRepEntities = bodyColl_2
oBaseFeature2 = oCompDef.Features.NonParametricBaseFeatures.AddByDefinition(nonParaDef)
Try : oBaseFeature2.Name = "Base2" : Catch : End Try
tiago.pereiraGB2J9
Thank you so much @Curtis_Waguespack!
This helps me. I´ll try to find a solution for the offshore plataform problem and when I have the anwers, I´ll post it here.
Thanks again for your time
