A crude Where-used to string Solution
maxim.teleguz
Message 1 of 8
maxim.teleguz
I am posting this in hopes that the community can share with me a better way.
Goal: to get the where used assembly from whatever is opened in a drawing. the code is launched from the drawing and it gets the information.
how: it is launched from an external Rule. you need two different rules.
first one that you will actually launch, can be named whatever you want that rule to be called. Launch it from a drawing and see how this works:
' opens the model attached
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim view As DrawingView = sheet.DrawingViews.Item(1)
Dim refDoc As Document = ThisApplication.Documents.Open(view.ReferencedFile.FullFileName)
Dim oFileName As String = ThisDoc.ModelDocument.FullFileName
Dim oFInfo As New IO.FileInfo(oFileName)
If oFInfo.IsReadOnly Then
	MsgBox("File is ReadOnly check out all the Models before attempting")
	refDoc.Close()
	Exit Sub
Try
' runs a rule inside the model
iLogicVb.RunExternalRule(refDoc.DisplayName, "where-used-to-custom-property")
Catch
iLogicVb.RunExternalRule("where-used-to-custom-property")
End Try
' saves and closes the model
refDoc.Save()
refDoc.Close()
Dim myparam As String
myparam = iProperties.Value("Custom", "WHERE-USED")
myparam = (Mid(myparam, 10, 9)).Trim
If myparam = "" Then Exit Sub
'pushes value from .idw to .ipt or .iam or vice versa (anything before = is what is being populated)
iProperties.Value("Custom", "Next Assy 1") = myparam
'iProperties.Value("Custom", "WHERE-USED") = "" 'keeping for debug purposes for now.
If iProperties.Value("Custom", "Next Assy 1") = iProperties.Value("Project", "Part Number") Then
MsgBox("Next Assembly cant be same part number, check again and run code again")
'refresh/update
InventorVb.DocumentUpdate()
second rule name it like this: where-used-to-custom-property
Imports System.Windows.Forms
Sub Main()
Dim fso As Object
Dim tabCtl As TabControl
Dim ctlCurrent As Control
Dim intPageNum As Integer
fso = CreateObject("Scripting.FileSystemObject")
ThisApplication.UserInterfaceManager.UserInteractionDisabled = False
 p = "WHERE-USED"
Try : x = iProperties.Value("Custom", p) : Catch : iProperties.Value("Custom", p) = "" : End Try
'Line1 :
ThisApplication.CommandManager.ControlDefinitions.Item("VaultShowDetailsTop").Execute2(False)
'vault1 = ThisApplication.CommandManager.ControlDefinitions.Item("VaultShowDetailsTop").Parent.ActiveCommand
'System.Windows.Forms.form.ActiveForm.Activate
'Dim afName As String = Form.ActiveForm.Name
'With vault1
'SendKeys.SendWait("{END}" & "{TAB}" & "{TAB}" & "{TAB}" & "{TAB}" & "{DOWN}" & "^c" & "% " & "{up}" & "{enter}")
SendKeys.SendWait("{END}" & "+{TAB}" & "{DOWN}" & "^c" & "% " & "{up}" & "{enter}")
'control.ActivateTab "Where Used"
'SelectTab = 1
'MsgBox(selectedtab)
 ' List all controls on the tab control in the Debug window.
iProperties.Value("Custom", p) = Clipboard.GetText
'End With
a = iProperties.Value("Custom", p)
'If Clipboard.ContainsText Then
'	Exit Sub
'End If
'GoTo Line1
		Dim TXT2Find As String = "File Name	Folder Path"
		Dim NewTXT As String = ""
		If a Like NewTXT Then
		MsgBox("nothing changed")
		Exit Sub
		Else
		a = Replace(a, TXT2Find, NewTXT)
		'a = Replace(a, subjectString, vbCrLf)
		'inputbox(replace$(subjectString, vbCrLf & vbCrLf, vbCrLf))
		iProperties.Value("Custom", p) = a
ThisApplication.CommandManager.StopActiveCommand
'iLogicVb.RunExternalRule("esc")
SendKeys.SendWait("{ESC}")
End Sub
Replies (7)
Message 2 of 8
maxim.teleguz
@Curtis_Waguespack any help will be most welcome
Message 3 of 8
Curtis_Waguespack
Hi @maxim.teleguz
I set up the 2 external rules and ran this on a simple drawing and it crashed Inventor (no worries, I didn't have any unsaved work open). In looking at the code, I see that there are some Vault calls involved. Unfortunately, I don't have a vault set up on this computer at the moment, and therefore I can't really investigate much further.
It looks interesting though!
I'm sure someone else will be able to have a look.
I hope this helps.
Curtis
Message 4 of 8
maxim.teleguz
Yes It does need Vault for it to work. Thank you for trying to help. (surprised you dont have vault considering how much you helped the community)
Message 5 of 8
matt_jlt
Hi, i know its probably a bit late but here is a script i wrote to access the vault-where used for a drawing.
It uses the vault api / no send keys stuff and has been very reliable for me. I use it daily on different vaults with no issues. Hopefully it helps you / at least gives you another way to achieve the same task.
https://github.com/mattjlt/Inventor-Code-Library/blob/master/Scripts/VAULT_Where%20Used.iLogicVb
Message 6 of 8
maxim.teleguz
the goal here is to spark some development in this area. We really need a where-used to iproperties function.
Any research shared is going to eventually lead to some great things for everyone. Thank you!
Message 7 of 8
maxim.teleguz
would you happen to know what type of error this is:
Error on Line 6 : Character is not valid.
Error on Line 63 : Type 'ACW.File' is not defined.
Error on Line 76 : Type 'acw.FileAssocLite' is not defined.
Error on Line 126 : Type 'ACW.File' is not defined.
Error on Line 135 : Type 'ACW.File' is not defined.
Message 8 of 8
matt_jlt
Hi, sorry about the errors. I had only tested that code out on Inventor 2019. Testing it out on 2021 shows there are some issues with it. I will try and fix them soon and will re-post.
