How to count specific hole features in an assembly environment
HYOSEOK-KIM
HYOSEOK-KIM
I am using Inventor 2024.
The logic to check the number of hole features used in a part in an assembly environment is structured as follows
Sub Main()
    Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
    Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
    Dim N As Integer = 0    'holes counter
    For Each oOcc As ComponentOccurrence In oAsmDef.Occurrences.AllLeafOccurrences
If Not oOcc.Suppressed Then
            If oOcc.DefinitionDocumentType = kPartDocumentObject Then
                Dim oDef As PartComponentDefinition = oOcc.Definition
                N += GetHolesQty(oDef)
            End If
        End If
    Next
    Beep
    MsgBox ("The number of holes in the current part is:  " & N)
End Sub
'''Calculates holes in the part document
'''Be careful: nested patterns are not analyzed !
Function GetHolesQty(ByVal oDef As PartComponentDefinition) As Integer
    Dim N As Integer = 0  'counter
    Dim oHoles As HoleFeatures = oDef.Features.HoleFeatures
    For Each oH As HoleFeature In oHoles
        If Not oH.Suppressed Then
            N += oH.HoleCenterPoints.Count
        End If
    Next
    'have we any rectangular patterns ?
    Dim oRectPatterns As RectangularPatternFeatures
    oRectPatterns = oDef.Features.RectangularPatternFeatures
    For Each oRPF As RectangularPatternFeature In oRectPatterns
        Dim m As Integer = 0
        If Not oRPF.Suppressed Then
            If (TypeOf oRPF.ParentFeatures.Item(1) Is HoleFeature) Then
                Dim oH As HoleFeature = oRPF.ParentFeatures.Item(1)
                    For Each oFPE As FeaturePatternElement In oRPF.PatternElements
                        If Not oFPE.Suppressed Then m += 1
                    Next
                End If
            End If
            N += m - 1
        Else
            N += m
        End If
    Next
    'have we any circular patterns ?
    Dim oCircPatterns As CircularPatternFeatures
    oCircPatterns = oDef.Features.CircularPatternFeatures
    For Each oCPF As CircularPatternFeature In oCircPatterns
        If Not oCPF.Suppressed Then
            If (TypeOf oCPF.ParentFeatures.Item(1) Is HoleFeature) Then
                Dim oH As HoleFeature  = oCPF.ParentFeatures.Item(1)
                    For Each oFPE As FeaturePatternElement In oCPF.PatternElements
                    Next
                End If
            End If
            N += m - 1
        Else
            N += m
        End If
    Next
    Return N
End Function
What I would like to ask is, is it possible to configure logic to identify the number of tabs used in an assembly, not all hole features, by type?
The message box is expressed as follows.
ex) 10 M3s, 2 M5s, etc.
I think it would be possible to configure the message box to display the type and number of holes by utilizing the part about HoleType.
Is it possible to configure it with logic?
JelteDeJong
You could try something like this:
Public Class ThisRule
    Private holes As Dictionary(Of String, Integer) = New Dictionary(Of String, Integer)()
    Sub Main()
                If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    GetHolesQty(oDef)
                End If
            End If
        Next
        Beep()
        Dim msg As String = ""
        For Each item As KeyValuePair(Of String, Integer) In holes
            Dim cell = String.Format("{0,-20}", item.Key)
            msg += String.Format("{0} : {1}{2}", cell, item.Value, System.Environment.NewLine)
        Next
        MsgBox(msg)
    End Sub
    Sub GetHolesQty(ByVal oDef As PartComponentDefinition)
                AddHoleInfo(oH, 1)
            End If
        Next
        Dim oRectPatterns As RectangularPatternFeatures = oDef.Features.RectangularPatternFeatures
            If oRPF.Suppressed Then Continue For
            Dim holes = oRPF.ParentFeatures.Cast(Of PartFeature).
                Where(Function(f) Not f.Suppressed And TypeOf f Is HoleFeature).ToList()
            If (holes.Count = 0) Then Continue For
            Dim elements = oRPF.PatternElements.Cast(Of FeaturePatternElement).
                Where(Function(fpe) Not fpe.Suppressed).ToList()
            For Each hole As PartFeature In holes
                AddHoleInfo(hole, elements.Count - 1)
            Next
        Next
            If oCPF.Suppressed Then Continue For
            Dim holes = oCPF.ParentFeatures.Cast(Of PartFeature).
            Dim elements = oCPF.PatternElements.Cast(Of FeaturePatternElement).
            Next
        Next
    End Sub
    Private Sub AddHoleInfo(hole As HoleFeature, numberOfHoles As Integer)
        Dim name As String = "Unknown"
        If (hole.Tapped) Then
            If (TypeOf hole.TapInfo Is HoleTapInfo) Then
                Dim info As HoleTapInfo = hole.TapInfo
                name = info.ThreadDesignation
            Else
                Dim info As TaperedThreadInfo = hole.TapInfo
            End If
        Else
            name = String.Format("Hole: {0}", hole.HoleDiameter.Expression)
        End If
        If holes.ContainsKey(name) Then
            holes(name) += numberOfHoles
        Else
            holes.Add(name, numberOfHoles)
        End If
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
HYOSEOK-KIM
Hello.
Thank you for your reply. There's something that needs to be corrected.
The logic reads the feature name "hole" and expresses it as a count.
The count I'm looking for is different information.
For example, assuming [Assembly 1] contains one [Part 1] and two [Part 2],
[Part 1] Hole1 feature contains two M6x1s, and Hole2 feature contains three M10x1s.
[Part 2] Hole1 feature contains one M6x1.
When executing the logic, I'd like the count results to be expressed as:
M6x1 = 4
M10x1 = 3
Concept:
- This is an assembly document.
- The total number of holes is ~.
- Of these, the number of holes with the "tap" attribute is ~.
- Of all the tap holes, the result would be ~ for "m1" and ~ for "m2"...
Is it possible to configure it with Inventor iLogic as above?
