How to close the inventor's dialog when open a dwg file?
1354448288
1354448288
When opening a dwg file, if the model and the dwg are in the same path, and the relationship between them is remained, the dwg file will be opened directly.
But when the relationship between them is broken, inventor will show a dialog like this:
and then, I clicked the 'Skip', it will show:
I need to close these dialogs silently.
How should I do with Inventor's API?
I tried Inventor.Application.ApplicationEvents, it helps nothing.
JelteDeJong
you could try this:
ThisApplication.SilentOperation = True
'open you document here
ThisApplication.SilentOperation = False
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you very much! It helps a lot.
