Change view label
Change view label
Tigerpirro
Change view label
Tigerpirro
Hi, I'm struggling a bit with a fairly simple issue. I'm trying to write a function that goes throught all views on a drawing. If that drawing has a active label I want the code to change the text.
This is just to quickly switch between languages.
I have tried using these as templates
Solved: ilogic code to change View Label Text - Autodesk Community - Inventor
I kinda get stuck when I need the Scale to come from the active view.
Could anyone help?
My code:
'start of ilogic codeDim oDoc As DrawingDocument:
oDoc = ThisDoc.Document
oModel = ThisDoc.ModelDocument
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheets = oDoc.Sheets
For Each oSheet In oSheets
oViews = oSheet.DrawingViews
    For Each oView In oViews
    oView.ShowLabel = True
        Try
        'add the custom iproperties to the view label
		oView.Label.FormattedText = "TEXT" & ActiveSheet.View("VIEW1").ScaleString
        Catch
        'do nothing if error
		End Try
    Next
Next
'end of ilogic code
JhoelForshav
Hi @Tigerpirro
If I understand correctly what you want, all you need is this code 🙂
For Each oSheet  As Sheet In ThisDrawing.Document.Sheets
    For Each oView As DrawingView In oSheet.DrawingViews
    If oView.ShowLabel Then oView.Label.FormattedText = "TEXT" & oView.ScaleString
    Next
Next
Tigerpirro
Thank you.
