How to change iPart instences through iLogic form?
jeeva.scientist
jeeva.scientist
1) I have an iPart with three rows of the table. so three parts with different dimensions.
2) they are
• Part1
• Part2
• Part3
3) now the first part1 is in active condition. I want to make part2 as active. But I want to do it from iLogic form by clicking a button or a dropbox or radio button
clutsa
Make a custom multi-value User Parameter (in this example its TargetPart) with your part names. Add a rule...
Dim doc As Document = ThisDoc.Document
Dim compDef As ComponentDefinition = doc.ComponentDefinition
Dim factory As iPartFactory = compDef.iPartFactory
Dim factoryRows As iPartTableRows = factory.TableRows
PartExists = False 'assume we won't find the part
For Each row In factoryRows
	If row.Item(2).value = TargetPart Then 'row.Item(2) is the Part Number column
		PartExists = True
		factory.DefaultRow = row
		Exit For
	End If
Next
If PartExists = False Then MessageBox.Show(TargetPart & " was not found.", "Title")
Create a new form and drag your user parameter (TargetPart) on to the form and save.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
jeeva.scientist
i am getting some error
clutsa
Leave the code just like I had it for the Row.Item(2).
Item(2) is the 2nd column in the row which happens to be the part number column. Row.Item(1) is the member name column if you want to look for member name not part numbers.
jeeva.scientist
I have attached the part file can you check if I made any other mistake, please.
clutsa
It's case sensitive. Try capitalizing the names in the list or add code to force the cases to be the same
	If UCase(row.Item(2).value) = UCase(TargetPart) Then 'row.Item(2) is the Part Number column
		PartExists = True
		Exit For
	End If
Next
jeeva.scientist
Working proofWorking proof
thank you very much for your support Mr. Andrew Cluts.
