I use the following little kludge to switch back and forth from my preferred scheme ("Millenium") and "Presentation" for printing screen shots.
Just call SwapColorScheme. This might not be what you're after, but you might be able to get something from it...
Public Sub SwapColorScheme()
If Len(SchemeName) < 1 And ThisApplication.ActiveColorScheme.Name = "Presentation" Then
SearchingForScheme = True
End If
If SearchingForScheme = True Then
Call NextScheme
Exit Sub
End If
If ThisApplication.ActiveColorScheme.Name <> "Presentation" Then
SchemeName = ThisApplication.ActiveColorScheme.Name
ThisApplication.ColorSchemes.Item("Presentation").Activate
Else
ThisApplication.ColorSchemes.Item(SchemeName).Activate
End If
End Sub
Public Sub NextScheme()
Dim Counter As Integer
Dim CurrentScheme As String
CurrentScheme = ThisApplication.ActiveColorScheme.Name
Counter = 1
Do While Counter < ThisApplication.ColorSchemes.count
'If CurrentScheme = ThisApplication.ColorSchemes.Item(Counter).Name Then
ThisApplication.ColorSchemes.Item(Counter + 1).Activate
If MsgBox("Do you like this scheme?", vbYesNo) = vbYes Then
SearchingForScheme = False
Exit Do
End If
'End If
Counter = Counter + 1
Loop
End Sub
This is my signature, not part of my post.
