How to Change Appearance of a solid Body in IPT in IAM Level?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I know the appearance in IPT can be manually changed in IAM level without modifying the IPT.
However, in my case, I prefer to change the appearance in certain solid body in IPT if it has multi solid bodies.
(I guess it will require user to select the solid).
I find similar topics in the iLogic forum but not match what I need.
Thanks for your help.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
