How to capture menu level events
I have created a custom menu to the Inventor addin. For this i follow the procedure given in the "CustomUI" section of the "Samples->SDK". Now, I want to re-paint my menu (by enabling/disabling) some menus depending upon some logic(an INI file values). For this I want to capture the event whenever user clicks on the top-level menu. Or any other event which is fired when user clicks on the "menu". I found one such event for "Context" menu but there is no such event for "Matrix" menu -
Can someone throw some light as to how to achieve this.
Any help will be help to me as i need this info urgently.
Amol
There is no event associated with menus being displayed, (other than for the
context menu, as you mentioned). In Inventor you can set the Enabled
property of the ButtonControlDefinition at any time. Any buttons associated
with the definition will automatically be enabled or disabled based on the
value of this property.
Brian Ekins
Autodesk Inventor API
wrote in message news:5202553@discussion.autodesk.com...
Amol
Thanks Brian for such an quick update.
I was luckier this time - I was able to address my problem using a different approach.
Amol
