How to Automatically Assign Layers to Angle Components and Retain Hidden Line Styles in Inventor .idw
william_brown11
william_brown11
I’m currently working on automating the layer assignment in my .idw drawings. I have a script that already automatically assigns components to their respective layers based on the material (e.g., assigning a specific layer to Angle Steel A36 or Tube Steel A36). This is working well for material-based layer assignment, but I am facing an issue with angle components and hidden lines.
Retaining the Hidden Line Style for Hidden Lines:
  • For hidden lines (lines that are not visible in the drawing view but are part of the geometry), I want them to remain as hidden lines (i.e., dashed lines) even after the layer is assigned.
  • The goal is that while the angle components are assigned to the 'Angle' layer, hidden lines should not change from their dashed appearance but still be part of that layer.
What I Have So Far:
  • I already have a script that changes the specified material to its corresponding layer. For example, all angle components are assigned to a Angle Steel A36 layer.
  • However, the hidden lines (that are part of these components) are not retaining their dashed line style after the layer change.
What I’m Looking For:
  • A solution that allows me to automatically assign the 'Angle' layer to angle components, but also ensures that hidden lines (such as the hidden parts of an angle component) remain dashed, as they should be according to the hidden line style.
Below is a picture of the angles showing the visible and hidden lines that I wish to maintain after running the script and the script itself.
If anyone can point me in the right direction or provide a script that can solve this issue, it would be greatly appreciated!
I am also looking for a script that will join all the lines of a part together so when I export to AutoCAD all the lines of a part are joined and it isn't a bunch of non-joined lines.
Thank you!
Sub Main
    drawDoc = TryCast(ThisDoc.Document, DrawingDocument)
    If (drawDoc Is Nothing) Then
       MessageBox.Show("This rule can only be run in a drawing,", "iLogic")
       Return
    End If
    ChangeLayerOfOccurrenceCurves()
End Sub
Private drawDoc As DrawingDocument
Public Sub ChangeLayerOfOccurrenceCurves()
    ' Process the occurrences, wrapping it in a transaction so the
    ' entire process can be undone with a single undo operation.
    Dim trans As Transaction
    trans = ThisApplication.TransactionManager.StartTransaction(drawDoc, "Drawing Layers by Materials")
    Try
        For Each dSheet As Sheet In drawDoc.Sheets
            For Each drawView As DrawingView In dSheet.DrawingViews
                ' Call the recursive function that does all the work.
                Dim docDesc As DocumentDescriptor
                docDesc = drawView.ReferencedDocumentDescriptor
                If (docDesc Is Nothing) Then Continue For
                If (docDesc.ReferencedDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject) Then Continue For
                Dim asmDef As AssemblyComponentDefinition
                asmDef = docDesc.ReferencedDocument.ComponentDefinition
                Call ProcessOccurrences(drawView, asmDef.Occurrences)
            Next
        Next
    Catch ex As Exception
        trans.Abort()
        Throw ex
    End Try
    trans.End()
End Sub
Private Sub ProcessOccurrences(ByVal drawView As DrawingView, _
   ByVal Occurrences As ComponentOccurrences)
    ' Iterate through the current collection of occurrences.
    Dim occ As ComponentOccurrence
    For Each occ In Occurrences
        If (occ.Suppressed) Then Continue For
        If (occ.Definition Is Nothing) Then Continue For
        ' Check to see if this occurrence is a part or assembly.
        If occ.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
            ' ** It's a part so get the material
            Dim subDoc As Document = occ.Definition.Document
            If (subDoc Is Nothing) Then Continue For
            Dim partDoc As PartDocument = subDoc
            Dim materialName = partDoc.ComponentDefinition.Material.Name
            ' Get the TransientsObjects object to use later.
            Dim transObjs As TransientObjects
            transObjs = ThisApplication.TransientObjects
            ' Verify that a layer exists for this material.
            Dim layers As LayersEnumerator
            layers = drawDoc.StylesManager.Layers
            On Error Resume Next
            Dim newLayer As Layer
            newLayer = layers.Item(materialName)
            If Err.Number <> 0 Then
                On Error Goto 0
                ' Copy an arbitrary layer giving it the name
                ' of the material.
                newLayer = layers.Item(1).Copy(materialName)
                ' Set the attributes of the layer to use the color,
                ' have a solid line type, and a specific width.
                '                    newLayer.Color = newColor
                newLayer.LineType = LineTypeEnum.kContinuousLineType
                'newLayer.LineWeight = 0.02
            End If
            On Error Goto 0
            ' Get all of the curves associated with this occurrence.
            Dim drawcurves As DrawingCurvesEnumerator
            drawcurves = drawView.DrawingCurves(occ)
            If Err.Number = 0 Then
                On Error Goto 0
                ' Create an empty collection.
                Dim objColl As ObjectCollection
                objColl = transObjs.CreateObjectCollection()
                ' Add the curve segments to the collection.
                Dim drawCurve As DrawingCurve
                For Each drawCurve In drawcurves
                    Dim segment As DrawingCurveSegment
                    For Each segment In drawCurve.Segments
                        objColl.Add(segment)
                    Next
                Next
                ' Change the layer of all of the segments.
                Call drawView.Parent.ChangeLayer(objColl, newLayer)
            End If
            On Error Goto 0
        Else
            ' It's an assembly so process its contents.
            Call ProcessOccurrences(drawView, occ.SubOccurrences)
        End If
    Next
End Sub
WCrihfield
My initial thought is that you would have to do a few things differently, which would likely slow the process down significantly.
  • Instead of using Sheet.ChangeLayer method (which is nice, and faster), you would have to deal with each DrawingCurveSegment individually.
  • Use more custom layers
    • A custom one just for the Visible (not 'Hidden') portion of the component's drawing view curves
    • A custom one just for the Hidden portion of the component's drawing view curves
    • Both their names can start with "Angle Steel A36", or whatever, but end differently, to indicate that difference
    • Both layers would obviously be set to the different 'Line Type', and possibly different Line Weight, etc.
  • As you get to each DCS (DrawingCurveSegment), check which 'Layer' it is already on, then optionally what that Layer's Line Type is, and use that to determine which of the two custom Layers to set that segment to.
Edit:  Actually, you could still use the Sheet.ChangeLayer method, but just use multiple ObjectCollections, then use that method multiple at the end, once for each custom Layer.  As you iterate through them, and check each segment's specs, you can put them in the appropriate collection.
Wesley Crihfield
(Not an Autodesk Employee)
william_brown11
That worked! Thank you!
