How to Automatically Assign Layers to Angle Components and Retain Hidden Line Styles in Inventor .idw
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I’m currently working on automating the layer assignment in my .idw drawings. I have a script that already automatically assigns components to their respective layers based on the material (e.g., assigning a specific layer to Angle Steel A36 or Tube Steel A36). This is working well for material-based layer assignment, but I am facing an issue with angle components and hidden lines.
Retaining the Hidden Line Style for Hidden Lines:
- For hidden lines (lines that are not visible in the drawing view but are part of the geometry), I want them to remain as hidden lines (i.e., dashed lines) even after the layer is assigned.
- The goal is that while the angle components are assigned to the 'Angle' layer, hidden lines should not change from their dashed appearance but still be part of that layer.
What I Have So Far:
- I already have a script that changes the specified material to its corresponding layer. For example, all angle components are assigned to a Angle Steel A36 layer.
- However, the hidden lines (that are part of these components) are not retaining their dashed line style after the layer change.
What I’m Looking For:
- A solution that allows me to automatically assign the 'Angle' layer to angle components, but also ensures that hidden lines (such as the hidden parts of an angle component) remain dashed, as they should be according to the hidden line style.
Below is a picture of the angles showing the visible and hidden lines that I wish to maintain after running the script and the script itself.
If anyone can point me in the right direction or provide a script that can solve this issue, it would be greatly appreciated!
Thank you!
Sub Main
drawDoc = TryCast(ThisDoc.Document, DrawingDocument)
If (drawDoc Is Nothing) Then
MessageBox.Show("This rule can only be run in a drawing,", "iLogic")
Return
End If
ChangeLayerOfOccurrenceCurves()
End Sub
Private drawDoc As DrawingDocument
Public Sub ChangeLayerOfOccurrenceCurves()
' Process the occurrences, wrapping it in a transaction so the
' entire process can be undone with a single undo operation.
Dim trans As Transaction
trans = ThisApplication.TransactionManager.StartTransaction(drawDoc, "Drawing Layers by Materials")
Try
For Each dSheet As Sheet In drawDoc.Sheets
For Each drawView As DrawingView In dSheet.DrawingViews
' Call the recursive function that does all the work.
Dim docDesc As DocumentDescriptor
docDesc = drawView.ReferencedDocumentDescriptor
If (docDesc Is Nothing) Then Continue For
If (docDesc.ReferencedDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject) Then Continue For
Dim asmDef As AssemblyComponentDefinition
asmDef = docDesc.ReferencedDocument.ComponentDefinition
Call ProcessOccurrences(drawView, asmDef.Occurrences)
Next
Next
Catch ex As Exception
trans.Abort()
Throw ex
End Try
trans.End()
End Sub
Private Sub ProcessOccurrences(ByVal drawView As DrawingView, _
ByVal Occurrences As ComponentOccurrences)
' Iterate through the current collection of occurrences.
Dim occ As ComponentOccurrence
For Each occ In Occurrences
If (occ.Suppressed) Then Continue For
If (occ.Definition Is Nothing) Then Continue For
' Check to see if this occurrence is a part or assembly.
If occ.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
' ** It's a part so get the material
Dim subDoc As Document = occ.Definition.Document
If (subDoc Is Nothing) Then Continue For
Dim partDoc As PartDocument = subDoc
Dim materialName = partDoc.ComponentDefinition.Material.Name
' Get the TransientsObjects object to use later.
Dim transObjs As TransientObjects
transObjs = ThisApplication.TransientObjects
' Verify that a layer exists for this material.
Dim layers As LayersEnumerator
layers = drawDoc.StylesManager.Layers
On Error Resume Next
Dim newLayer As Layer
newLayer = layers.Item(materialName)
If Err.Number <> 0 Then
On Error Goto 0
' Copy an arbitrary layer giving it the name
' of the material.
newLayer = layers.Item(1).Copy(materialName)
' Set the attributes of the layer to use the color,
' have a solid line type, and a specific width.
' newLayer.Color = newColor
newLayer.LineType = LineTypeEnum.kContinuousLineType
'newLayer.LineWeight = 0.02
End If
On Error Goto 0
' Get all of the curves associated with this occurrence.
Dim drawcurves As DrawingCurvesEnumerator
drawcurves = drawView.DrawingCurves(occ)
If Err.Number = 0 Then
On Error Goto 0
' Create an empty collection.
Dim objColl As ObjectCollection
objColl = transObjs.CreateObjectCollection()
' Add the curve segments to the collection.
Dim drawCurve As DrawingCurve
For Each drawCurve In drawcurves
Dim segment As DrawingCurveSegment
For Each segment In drawCurve.Segments
objColl.Add(segment)
Next
Next
' Change the layer of all of the segments.
Call drawView.Parent.ChangeLayer(objColl, newLayer)
End If
On Error Goto 0
Else
' It's an assembly so process its contents.
Call ProcessOccurrences(drawView, occ.SubOccurrences)
End If
Next
End Sub
