How to : Add Ribbon Tab, Panels and Button ??
Message 1 of 10
I have already write a Macro in VBA which functions as a button. I want to add a new tab with panels and buttons in these panels. So what I suppose to do is:
1/ Create tab and panels
2/ Add button in panels
This is the code I write to do the first step:
[code]
  ' Make sure a part document is active
        Dim oAsmDoc As AssemblyDocument
        oAsmDoc = mApp.ActiveDocument
        ' Get the part ribbon
        Dim oAsmRibbon As Ribbon
        oAsmRibbon = mApp.UserInterfaceManager.Ribbons.Item("Assembly")
        ' Create a new tab before the Assemble Tab
        Dim oProTab As RibbonTab
        oProTab = oAsmRibbon.RibbonTabs.Add("Pro", "Id_TabPro", "ClientId12345", "id_TabAssemble", True, False)
         oProTab.Visible = True
        'Create a new panel on the Promecon tab
        Dim oPanel(4) As RibbonPanel
        oPanel(1) = oProTab.RibbonPanels.Add("Model", "id_PanelA_PromeconModel", "ClientId12345")
        oPanel(2) = oProTab.RibbonPanels.Add("Drawing", "id_PanelA_PromeconDrawing", "ClientId12345")
        oPanel(3) = oProTab.RibbonPanels.Add("BonusTools", "id_PanelA_PromeconBonusTools", "ClientId12345")
        oPanel(4) = oProTab.RibbonPanels.Add("Report", "id_PanelA_PromeconReport", "ClientId12345")
[end code]
        The fault exists in the bold line.  I think the problem is the ClientId. In the API Online Class Material, they say that "ClientId   -  Input String that uniquely identifies the client. This is the CLSID of the AddIn in a string form, e.g. "{C9A6C580-3817-11D0-BE4E-080036E87B02}". It is not   recommended to pass a “dummy” string or a null string.". But I cann't find out what ClientId is suitable and reasonable.
2/ How to convert an VBA modules to a button and add it to panel
Thank you so much!
Replies (9)
Message 2 of 10
YuhanZhang
There is no fault for the bold line, it succeeds when you run the code for first time. But it would fail if you run it twice if you forgot to clean up the ribbon tab you created last time. So to avoid the failure you can check if a ribbon tab with the ClientIDd already exists.
To convert a VBA modules to a button I suggest you to read Mr. Brian's paper:
http://modthemachine.typepad.com/files/Upgrading to Ribbon.pdf
you can find it on the post Upgrading your add ins to support the ribbon user interface.
Please let me know if I can help more.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 3 of 10
I am reading that paper but I still can't find the solution.
To check that tab, do I use Try method as some code in API Online Class?
I already try it, but it still doesn't work.
Sorry for me, I just begin in API with a very little knowledge in VB.NET
Message 4 of 10
ekinsb
I think the main issue is that adding new ribbon elements wasn't ever intended to be used from VBA but from an add-in.  It can be used, but has issues.  One of the main ones is that any changes you make to the ribbon are forgotten the next time you run Inventor.  You're program would need to be re-run for each session.  An add-in also has the same issue but because Inventor automatically runs add-ins each time Inventor is started they have a chance to re-created their user-interface.
If you're far enough along with programming Inventor that you want to customize the user-interface, I would strongly recommend looking at writing add-ins instead of using VBA.
This post contains a document that describes how to write an add-in.
http://modthemachine.typepad.com/my_weblog/2010/01/how-to-write-an-inventor-add-in.html
Brian Ekins
Mod the Machine blog
Message 5 of 10
I will research Upgrading Your AutoDesk Inventor Add-Ins to Use the New Ribbon User Interface  &  Taking the Step from VBA Macros to Autodesk Inventor Add-Ins. I hope that I can figure out how to solve this problem.
Could you please to answer another question in the first problem. As Mr. Rocky Zhang said, I find out that the bold line is right when I press the button first time. If I press the second time, error will exist b/c the later Client-Id coincides with the first Client-Id.
However,when I press the first time,  the new tab exists just for a moment (less than 1 second) and disappears. What should I do if I want to show it when Inventor still running.
I know to show it permanently; I must use Add-In. But now I just want to show it until Inventor shut down.
 Does it relate to the Environment? Override or Parallel Environment?? Or anything else?
Thank you so much!
Message 6 of 10
I got that after I close all assembly document and reopen them. Now I think that when i run the code, I must reopen that environment (assembly, part, etc.) to get the affect.
I have 1 more question. I want to get part documents in an assembly. I already write the code, but it doesn't work.
[code]
        Dim oFileType As FileTypeEnum
        If oFileType = FileTypeEnum.kAssemblyFileType Then
            ' Set a reference to the assembly component definintion.
            ' This assumes an assembly document is open.
            Dim oAsmCompDef As AssemblyComponentDefinition
            oAsmCompDef = mApp.ActiveDocument.ComponentDefinition
            ' Get the occurrence.
            Dim oOcc As ComponentOccurrence
            Dim i As Integer = 0
            For i = 1 To 500
                oOcc = oAsmCompDef.Occurrences.Item(i)
                oBlockPart = oOcc
                CreateDrawing()
            Next
        End If
[end code]
With CreateDrawing() is a small sub that create a drawing with an editing part. CreateDrawing() works very well with this oBlockPart:
Dim oBlockPart As PartDocument
oBlockPart = mApp.ActiveEditDocument
So, please show me what problem with the upper code, I just want get the parts in assembly. Does the bold line correct?
Message 7 of 10
ekinsb
The ComponentOccurrence object represents the occurrence instance in the assembly and is not a part document.  However, you can access the part or assembly document that the occurrence references.  In your code you would edit to the following:
   oBlockPart = oOcc.Definition.Document
   CreateDrawing()
Brian Ekins
Message 8 of 10
Thank you so much, it works very well.
I just think more deeply and I have a more specific question about the file name. In my assembly, I have a few type of name for part, such as PL-x, PROF-x, LPL-x, LPROF-x, etc (with x is the number). I use the property FullFileName, but it doesn't work.
[code]
        ' Number the occurrence and add its value to oBlockPart
        For i = 1 To 500
            If oBlockPart.File.FullFileName = "*PL*.ipt" Then
                CreateDrawing()
            End If
        Next
[code]
What property I should use?
Thank you so much. I really appreciate all thing you done!
Message 9 of 10
ekinsb
Is the line you're using exactly this?
If so, then you'll likely never enter the If statement because it's trying to match the name exactly, even with the asterisks.  A simple string comparison, like you're doing here does not take into account any wild card characters.  Instead, you'll probably want to use the Like operator.
    If oBlockPart.File.FullFileName Like "*PL*.ipt" Then
Brian Ekins
Message 10 of 10
Thank you so much! I got what I want.
I just find out Overview Articles in Programming Help. It is very very good for me to learn. It has description, explanation, and example code. Now I'm beginning to study all in Programming Help to have an enough knowledge to work in API.
Thank you again, see you later!
