How to add more Scale to inventor 2020
Darkforce_the_ilogic_guy
Advisor Advisor
how to I add more Scale (On Drawings idw)to inventor 2020? I did find some version of this online .. But could not find it in the Style Editor.
I would like to know where this is save as well. sind I need to get this out on multi computers hope you can help with one or both of my problem
JhoelForshav
It's in the style editor. Select your standard. Under general tab you have a group called Preset Values. Select Scale from the dropdown there and click new 🙂
I can´t see that grounp
oh wait hehe... I miss the point of change the dropdown menu thankt
JhoelForshav
In the drop down that says Line Weights...
WCrihfield
Here is a couple of iLogic rules I wrote about a year ago for this scenario.
It sets up all the scales I want to be available (similarly to the manual process mentioned in this post).
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOK, "WRONG DOCUMENT TYPE")
	Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oScalesList As New List(Of String)
oScalesList.Add("1 / 30")
oScalesList.Add("1 / 29")
oScalesList.Add("1 / 28")
oScalesList.Add("1 / 27")
oScalesList.Add("1 / 26")
oScalesList.Add("1 / 25")
oScalesList.Add("1 / 24")
oScalesList.Add("1 / 23")
oScalesList.Add("1 / 22")
oScalesList.Add("1 / 21")
oScalesList.Add("1 / 20")
oScalesList.Add("1 / 19")
oScalesList.Add("1 / 18")
oScalesList.Add("1 / 17")
oScalesList.Add("1 / 16")
oScalesList.Add("1 / 15")
oScalesList.Add("1 / 14")
oScalesList.Add("1 / 13")
oScalesList.Add("1 / 12")
oScalesList.Add("1 / 11")
oScalesList.Add("1 / 10")
oScalesList.Add("1 / 9")
oScalesList.Add("1 / 8")
oScalesList.Add("1 / 7")
oScalesList.Add("1 / 6")
oScalesList.Add("1 / 5")
oScalesList.Add("1 / 4")
oScalesList.Add("1 / 3")
oScalesList.Add("1 / 2")
oScalesList.Add("1 : 1")
oScalesList.Add("2 : 1")
oScalesList.Add("3 : 1")
oScalesList.Add("4 : 1")
oScalesList.Add("5 : 1")
oScalesList.Add("6 : 1")
oScalesList.Add("7 : 1")
oScalesList.Add("8 : 1")
oScalesList.Add("9 : 1")
oScalesList.Add("10 : 1")
Dim oScales As String() = oScalesList.ToArray()
oDDoc.StylesManager.ActiveStandardStyle.PresetScales = oScales
And also a rule to set all the Text Heights that I want to be available within the Text Height drop-down.
	Return
End If
Dim oPTextHeights As New List(Of Double)
oPTextHeights.Add(0.080*2.54)
oPTextHeights.Add(0.100*2.54)
oPTextHeights.Add(0.125*2.54)
oPTextHeights.Add(0.150*2.54)
oPTextHeights.Add(0.1875*2.54)
oPTextHeights.Add(0.250*2.54)
oDDoc.StylesManager.ActiveStandardStyle.PresetTextHeights = oPTextHeights.ToArray
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
