how to Add ModelSurfaceTextureSymbols
SachinRane
Message 1 of 8
SachinRane
Hi
I am Trying to add the Model Annotation.
In Model annotation I am trying to Add the ModelSurfaceTextureSymbols and LeaderNoteText How to do Create the Defination for the same.
Accepted solutions (4)
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @SachinRane,
Try the below VBA code to add ModelSurfaceTextureSymbols and ModelLeaderNote.
Sub Main()
    Dim doc As PartDocument
    Set doc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = doc.ComponentDefinition
    Dim oFace As Face
    Set oFace = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select a face to add leader point")
    Dim oAnnotationPlaneDef As AnnotationPlaneDefinition
    Set oAnnotationPlaneDef = oDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oFace)
    ' Set a reference to the TransientGeometry object.
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oSurfacePoints As ObjectCollection
    Set oSurfacePoints = ThisApplication.TransientObjects.CreateObjectCollection
    ' Create a few leader points.
    Call oSurfacePoints.Add(oTG.CreatePoint(10, 15, 0))
    Dim oIntent As GeometryIntent
    Set oIntent = oDef.CreateGeometryIntent(oFace)
    Call oSurfacePoints.Add(oIntent)
    Dim oSurfaceTexDef As ModelSurfaceTextureSymbolDefinition
    Set oSurfaceTexDef = oDef.ModelAnnotations.ModelSurfaceTextureSymbols.CreateDefinition(oSurfacePoints, oAnnotationPlaneDef)
    Dim oSurfaceTexture As ModelSurfaceTextureSymbol
    Set oSurfaceTexture = oDef.ModelAnnotations.ModelSurfaceTextureSymbols.Add(oSurfaceTexDef)
    Dim oLeaderPoints As ObjectCollection
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    Call oLeaderPoints.Add(oTG.CreatePoint(5, 10, 0))
    Dim oLeaderIntent As GeometryIntent
    Set oLeaderIntent = oDef.CreateGeometryIntent(oFace)
    Call oLeaderPoints.Add(oLeaderIntent)
    Dim oLeaderDef As ModelLeaderNoteDefinition
    Set oLeaderDef = oDef.ModelAnnotations.ModelLeaderNotes.CreateDefinition(oLeaderPoints, "Sample", oAnnotationPlaneDef)
    Dim oLeader As ModelLeaderNote
    Set oLeader = oDef.ModelAnnotations.ModelLeaderNotes.Add(oLeaderDef)
End Sub
On running above code, it prompts for selection of face as shown below.
After selection of face, sample ModelSurfaceTextureSymbol and ModelLeaderNote are added at different location as shown below.
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
SachinRane
Thanks for your help in Adding ModelSurfaceTextureSymbols, I am trying to add the tolerence Feature using the ModelCompositeAnnotation or the trying to add the ModelFeatureFrame but its giving the Error. Can you Help me out
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@SachinRane,
Try below VBA code to add ModelFeatureControlFrame. There must be at least one row in ModelFeatureControlFrame while adding.
Sub Main()
    Dim oFace As Face
    Set oFace = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select a face to add Model feature control frame")
    Dim oPt As Point
    Set oPt = oTG.CreatePoint(12, 15, 0)
    Dim oMFCFDef As ModelFeatureControlFrameDefinition
    Set oMFCFDef = oDef.ModelAnnotations.ModelFeatureControlFrames.CreateDefinition(oIntent, oAnnotationPlaneDef, oPt)
    Dim oMFCFRow As ModelFeatureControlFrameRow
    Set oMFCFRow = oMFCFDef.FeatureControlFrameRows.Add(kFlatness, 0.02)
    Dim oMFCF As ModelFeatureControlFrame
    Set oMFCF = oDef.ModelAnnotations.ModelFeatureControlFrames.Add(oMFCFDef)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
SachinRane
Thanks For your support
but i am trying to add the ModelCompositeAnnotation, I Can do that
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@SachinRane,
Yes, You can use same ModelFeatureControlFrame to add a ModelCompositeAnnotation.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
SachinRane
I am Trying to Set the Standerd for the ModelSurfaceTexture via API, it is possible in Drafting but how to do the Same for the ModelSurfaceTextureSymbols. Figure 2 is the Required result and Figure 3 is API Result. How I can achive the Same.
Figure 1 is need to Set the STD. I want to set the ANSI Std for ModelSurfaceTextureSymbols
Message 8 of 8
josh.nieman
This has been a very good teaching tool for me.  I'm having a particular issue where Inventor will crash when running this method, if a non-planar face is selected.  If, say, a cylindrical face is selected
oAnnoPlaneDef = oDoc.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oFace)
Fails
and Inventor crashes.
I have tried instead using kAllPlanarEntities instead, but that similarly failed.
What would be the best route to constrain the user to selecting only valid planar faces, or being able to handle a nonplanar face selection?
Thanks in advance.
IMPORTANT EDIT
I'm working in an assembly environment, rather than part.  Trying to add ModelLeaderNotes
