How to add ModelLeaderNotes accurately in assembly
bindlmi
Message 1 of 1
bindlmi
actually I am able to place a ModelLeaderNote in an assembly, but I can't controll, how it is placed. I'm afraid, there are no APIs in Inventor 2018.3.3. - well, we will see.
The following Code allows me to pick a face and to pick a Point, then it creates a ModelLeaderNote with "test" in my assebly - but not as it should. (oDoc and oCompDef are declared global)
I thought, that the AnnotationPlaneDefinition is the plane, where my text lies on (when I place a note by hand, I can switch between them with space). But it seems to be the plane, where the root gets created.
And the oLeaderPoints in the ObjektCollection is where the text is placed, and not where the root from the note is.
Are there any other APIs or workarounds for my problem?
Private Sub CommandButton1_Click()
Dim oMLNs As ModelLeaderNotes
Set oMLNs = oCompDef.ModelAnnotations.ModelLeaderNotes
Dim oMLN As ModelLeaderNote
Dim oMLNDef As ModelLeaderNoteDefinition
Dim oFace As Face
Set oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face")
Dim oAnnoPlaneDef As AnnotationPlaneDefinition
Set oAnnoPlaneDef = oCompDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oFace.Geometry)
Dim oLeaderPoints As ObjectCollection
Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
Dim oPoint As Variant
Set oPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select Point")
Dim NewPoint As Point
Set NewPoint = ThisApplication.TransientGeometry.CreatePoint(oPoint.Point.X, oPoint.Point.Y, oPoint.Point.z)
Call oLeaderPoints.Add(NewPoint)
Dim oLeaderIntent As GeometryIntent
Set oLeaderIntent = oCompDef.CreateGeometryIntent(oFace)
Call oLeaderPoints.Add(oLeaderIntent)
Set oMLNDef = oMLNs.CreateDefinition(oLeaderPoints, "test", oAnnoPlaneDef)
Set oMLN = oMLNs.Add(oMLNDef)
End Sub
Kind regards
Michael
Replies (0)
