How to add centerline on drawing view having 2 drawing curves?
Hubert_Los
Hubert_Los
How can I use the function below:
Centerlines.Add( CenterEntities As ObjectCollection, [CentermarkStyle] As Variant, [Layer] As Variant, [Closed] As Boolean ) As Centerline
I need CenterEntities. How to create them, having 2 DrawingCurves from the drawingView?
Michael.Navara
Can you be more descriptive? Attach some image what do you want to do.
If you expect centerline between two lines, use AddBisector() method instead
Dim sheet As Sheet = ThisDrawing.ActiveSheet.Sheet
Dim drwView As DrawingView = sheet.DrawingViews(1)
Dim curve1 As DrawingCurve = drwView.DrawingCurves.Item(1)
Dim curve2 As DrawingCurve = drwView.DrawingCurves.Item(2)
Dim intent1 As GeometryIntent = sheet.CreateGeometryIntent(curve1)
Dim intent2 As GeometryIntent = sheet.CreateGeometryIntent(curve2)
sheet.Centerlines.AddBisector(intent1, intent2)
Hubert_Los
This is what I needed,
Thank You
