Can I get it to paint all the A-side and not only one surface?
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 10
I have a ilogic code , that paint the A-side on sheet metal , if the material is not the same on both side ,,, but if I have a bent part .. not all of if this paintet on the fold part .. is there a way to fix that?
Replies (9)
Message 2 of 10
Cadkunde.nl
I see no ilogic rule in the part, could it have been an external rule
I feel its that you are only painting the first face, not the whole collection
Message 3 of 10
Cadkunde.nl
Here is how i find and select all 3 faces of the A-Side
Dim odoc As PartDocument = ThisDoc.Document
Dim smcomp As Inventor.SheetMetalComponentDefinition = odoc.ComponentDefinition
Dim aside As Inventor.ASideDefinition = smcomp.ASideDefinitions.Item(1)
Dim sel As Inventor.SelectSet = odoc.SelectSet
MsgBox(aside.Faces.Count)
For i = 1 To aside.Faces.Count
	sel.Select(aside.Faces.Item(i))
Next
Message 4 of 10
Michael.Navara
I don't know how you set the color to ASideFace, but here is the next step, how to apply the same Appearance to tangentially connected faces
Dim part As PartDocument = ThisDoc.Document
Dim smCompDef As SheetMetalComponentDefinition = part.ComponentDefinition
Dim aSideFace As Face = smCompDef.ASideFace
For Each tangentFace As Face In aSideFace.TangentiallyConnectedFaces
	tangentFace.Appearance = aSideFace.Appearance
Next
Message 5 of 10
nstevelmans
Hi All,
Try this,
Dim oPartDoc As PartDocument =  ThisDoc.Document
        Dim oSheetMetalCompdef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
        Dim assetLib As AssetLibrary
        assetLib = ThisApplication.AssetLibraries.Item("Inventor material Library")
        Dim libAsset As Asset = assetLib.AppearanceAssets.Item("Red")
        'get a 'local copy' of this appearance to work with (needed)
        Dim oDocApps As AssetsEnumerator = oPartDoc.AppearanceAssets
        Dim oAppAsset As Asset = Nothing
        Try
            oAppAsset = oDocApps.Item("Red")
        Catch
            oAppAsset = libAsset.CopyTo(oPartDoc, True)
        End Try
        Dim oListFaces As New List(Of Faces)
        Dim oAsideDef As ASideDefinition = oSheetMetalCompdef.ASideDefinitions.Item(1)
        For Each face As Face In oAsideDef.Faces
            Face.Appearance = oAppAsset
        Next
Message 6 of 10
Sorry I seens for have fail in sending the ilogic with ... but here it is
'this code paint the A-side same color as the material without the pattern on
'version 1.05
'Add Faom CO35
'version 1.06
Dim runscript As Boolean
runscript = False
If ThisDoc.Document.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	'MsgBox("This is not a Sheet Metal Part. Exiting rule.", vbCritical, "")
	Exit Sub
Dim CurrentSM_Style = SheetMetal.GetActiveStyle()
Dim color
If CurrentSM_Style  = "St.S235 | Tear Plate |2000x1000x3" Or CurrentSM_Style = "St.S235 | Tear Plate |2500x1250x3" Or CurrentSM_Style = "St.S235 | Floor Plate |2500x1250x5" Or CurrentSM_Style = "St.S235 | Floor Plate |3000x1500x5" Then
	runscript = True
	Color = "Steel"
If CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 2000x1000x5" Or CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 2500x1250x5" Or CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 2500x1250x5*" Or CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 3000x1500x5" Then
	runscript = True
	Color = "Aluminium"
If CurrentSM_Style = "Pl Flexfoam CO35 | Sound Absorption Plate | 1200x1500x30" Then
	runscript = True
	Color = "RAL 1021 Rape yellow"
'MsgBox(Color)
If CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 2000x1000x5" Or CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 2500x1250x5" Or CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 2500x1250x5*" Or CurrentSM_Style = "Alu AW-5754 H114 | Floor Plate | 3000x1500x5" Or CurrentSM_Style = "St.S235 | Tear Plate |2000x1000x3" Or CurrentSM_Style = "St.S235 | Tear Plate |2500x1250x3" Or CurrentSM_Style = "St.S235 | Floor Plate |2500x1250x5" Or CurrentSM_Style = "St.S235 | Floor Plate |3000x1500x5" Then
	runscript = True
Else
	'Exit Sub
If runscript = False Then
	Exit Sub
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
Dim oFaceToChange As Face = Nothing
If oSMDef.ASideDefinitions.Count > 0 Then
	oFaceToChange = oSMDef.ASideDefinitions.Item(1).ASideFace
If IsNothing(oFaceToChange) Then
	'try to get the 'BaseFace' from the FlatPattern
	Dim oFP As FlatPattern = Nothing
	If oSMDef.HasFlatPattern Then
		oFP = oSMDef.FlatPattern
	Else
		Try
			oSMDef.Unfold
			oFP.ExitEdit
		Catch
			MsgBox("Error unfolding part to get FlatPattern.", vbCritical, "")
			Exit Sub
		End Try
	If IsNothing(oFP) Then Exit Sub
	oFaceToChange = oFP.BaseFace 'usually the stationary face when others unfold
	'oFaceToChange = oFP.BottomFace
'get/specify appearance type Asset to supply as value to face appearance
'Dim oInvMatLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Inventor Material Library")
Dim oInvMatLib As AssetLibrary = ThisApplication.AssetLibraries.Item("KallesoeMaterialLibrary")
Dim oWhite As Asset = oInvMatLib.AppearanceAssets.Item(Color)
'Dim oWhite As Asset = oInvMatLib.AppearanceAssets.Item(Steel)
'Asset = oInvMatLib.AppearanceAssets.Item("Steel")
Dim oDocApps As AssetsEnumerator = oPDoc.AppearanceAssets
Try
	oAppAsset = oDocApps.Item(Color)
Catch
	oAppAsset = oWhite.CopyTo(oPDoc, True)
End Try
oFaceToChange.Appearance = oAppAsset
'oFaceToChange.AppearanceSourceType = AppearanceSourceTypeEnum.kOverrideAppearance
Message 7 of 10
I use your code to modify my code ... so now it does paint the A-side if the A-side is add by the user. but I need it to work even if the A-side is not define by the user . My code now look like this
'version 1.05
'Add Faom CO35
'version 1.06
runscript = False
	Exit Sub
Dim color
	runscript = True
	Color = "Steel"
	runscript = True
	Color = "Aluminium"
	runscript = True
'MsgBox(Color)
	runscript = True
Else
	'Exit Sub
	Exit Sub
	Else
		Try
			oSMDef.Unfold
			oFP.ExitEdit
		Catch
			Exit Sub
		End Try
Try
Catch
End Try
Try
 Dim oAsideDef As ASideDefinition = oSMDef.ASideDefinitions.Item(1)
        Next
Catch
'error if aside is not add jet
'How does I get it to paint the side that would be the a-side ?
End Try
If the A-side is add by the user it now paint all of it ... but I it is not ..It will cause an error and only paint one surface. any idear how to get it to paint all the A-side face on both cases?
Message 8 of 10
you code work fine if I have a-side in the browser tree , but I need  it to work even if it is not. My our code does but does not paint all the surface if there is more then one(i case of a ben part) I need to get it to work if there is a A-side or not... and it both case where there are one or more then one A-side Faces
Message 9 of 10
Cadkunde.nl
Is it always obvious which side is Aside?
Is it always the largest side? Does it matter with bends up or bends down direction?
Will this be 100% foolproof without engineer?
If so, then we need input on how to automatically make the aside.
If its better the engineer looks at it: just notify the engineer to create the Aside when saving:
(Add this to event before save for part documents)
If ThisDoc.Document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oPDoc As PartDocument = ThisDoc.DocumentDim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
If oSMDef.ASideDefinitions.Count = 0 Then
Msgbox(“You forgot aside")
Message 10 of 10
Well we already have a code to create A-side for the users. most material is does not matter with is the A-side.  but we does have some material when it matter a lot. like floor plate. where the two sides are not the same. Color the A-side is a way to make it visible if you have hade the side choss both for the engineer and the guy in the work shop- That is create the physiscal part
