How to add a Column in a Partslist with kMaterialPartsListProperty (combined Field material / vendor)
wolfgang_nickl
Message 1 of 10
wolfgang_nickl
Hello together,
I want to add colums to a partslist with API. The following VBA sub inserts four different values in a Partslist.
Public Sub subTestPartslistInsertColumn()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    'The Partslist to change is selected, get it
    Dim oPartsList As PartsList
    Set oPartsList = oDoc.SelectSet(1)
    'add new user "Inventor User Defined Properties" RAL
    Call oPartsList.PartsListColumns.Add(kCustomProperty, , "RAL")
    'add ItemNumber
    Call oPartsList.PartsListColumns.Add(kItemPartsListProperty, , "ItemNumber")
    'add "Design Tracking Properties" description
    Call oPartsList.PartsListColumns.Add(kFileProperty, "{32853F0F-3444-11D1-9E93-0060B03C1CA6}", "29")
    'Add the quantity
    Call oPartsList.PartsListColumns.Add(kItemQuantityPartsListProperty, , "ItemQuantity")
End Sub
What I can't figur out is how to insert the combined Field for Material / Vendor. I found out that I have to use kMaterialPartsListProperty, but where I can find the values for PropertySetId and PropertyIdentifier?
Best Regards
Wolfgang
Replies (9)
Message 2 of 10
@wolfgang_nickl . This works for me.
Put them together in a "For" loop.
'Add Columns
oColumns.Add(kMaterialPartsListProperty, "{32853F0F-3444-11D1-9E93-0060B03C1CA6}", "20")
oColumns.Add(kFileProperty, "{32853F0F-3444-11D1-9E93-0060B03C1CA6}", "30")
oColumns.Add(kCustomProperty, , "Mat_Ven")
'ADD VALUE TO CUSTOM COLUMN
For i = 1 To oPList.PartsListRows.Count
VendorValue = oPList.PartsListRows.Item(i).Item("Vendor").Value
MaterialValue = oPList.PartsListRows.Item(i).Item("Material").Value
Mat_Ven = oPList.PartsListRows.Item(i).Item("Mat_Ven")
Mat_Ven.Value = VendorValue & ": " & MaterialValue
Next
Message 3 of 10
wolfgang_nickl
Hello JoJo.S,
thank you for your reply, but this isn't the solution.
I need the property von Partslist as shown in the dialog.
As I use a german Inventor I can't tell you the exact naming, but please have a look at the picture.
The Red marked Bauteilliste (1) meens Partslist and Werkst./Lieferant (2) means material/vendor.
I need excatly this property, it delievers only vendor if defined, and material if there is no vendor.
Your solution isn't compatible with our PDM Solution.
Best Regards
Wolfgang
Message 4 of 10
@wolfgang_nickl  Which version you are using?
Message 5 of 10
wolfgang_nickl
Hello Jojo.S,
we use Inventor 2021, but its the same behaviour in previous versions.
Best Regards
Wolfgang
Message 6 of 10
Hi @wolfgang_nickl . How did you put it under Partslist (manually)? I dont have that option. And also cannot create a custom parameter with that name. I have to find out.
Message 7 of 10
wolfgang_nickl
Hello JoJo.S,
with an open Drawing I go to Ribbon Manage (German: Verwalten) -> Styleeditor (German: Stil- und Normeneditor) -> Partslist (German: Teileliste (DIN)) -> Columnselection (German: Spaltenauswahl) and thats the dialog you can see in the previous picture. The next two pictures show the way.
Best Regards
Wolfgang
Message 8 of 10
wolfgang_nickl
Hello JoJo.S,
I forgot one point, could it be that your MATERIAL is the German Werkst./Lieferant?
Best Regards
Wolfgang
Message 9 of 10
Hi @wolfgang_nickl . So, what you need is an ilogic to do the same as the substitution option. sUBS.JPG
Message 10 of 10
wolfgang_nickl
Hello JoJo.S,
if I don't find an api-call to insert that column we have to do it manualy because the mapping with our PDM is on that field. I know the possibility of your idea with iLogic, but it doesn't work for me.
Best Regards
Wolfgang
