How to Access Iproperty of DWG files opened from an Assembly Referenced Documents?
wCorreiaHBYAR
wCorreiaHBYAR
HI, I am able to open and SAVE as PDF for the DWG that are linked to an Assembly. But I am not able to get the REV # that is in the Custom iproperty of each DWG.
I used the below line in many ways but no success:
iProperties.Value("Custom", "REV #")
 But since  I am running the RULE from an assembly. The RULE does not pick up the REV# that is in the DWG's "Custom" iproperty. Looks like I am missing a piece of code that will do it. I plan to use that REV# and put it in the PDF file name that is generated. Can anyone help me? Here is my entire code:
Sub Main()
    Dim oDoc As Document
    oDoc = ThisDoc.Document
    oDocName = System.IO.Path.GetDirectoryName(oDoc.FullFileName) & "\" & System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
'	oFile = GetFileNameWithoutExtension(oDoc.FullFileName)
    'MessageBox.Show(oFile, "Title")
    If Not (oDoc.DocumentType = kAssemblyDocumentObject Or oDoc.DocumentType = kDrawingDocumentObject) Then
        MessageBox.Show("Please run this rule from the assembly or drawing files.", "iLogic")
        Exit Sub
    End If
    'get user input
    If MessageBox.Show ( _
        "This will create a PDF file for all of the files referenced by this document that have drawings files." _
        & vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
        & vbLf & " " _
        & vbLf & "Are you sure you want to create PDF Drawings for all of the referenced documents?" _
        & vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo) = vbNo Then
        Exit Sub
    End If
    Dim PDFAddIn As TranslatorAddIn
    Dim oContext As TranslationContext
    Dim oOptions As NameValueMap
    Dim oDataMedium As DataMedium
    Call ConfigurePDFAddinSettings(PDFAddIn, oContext, oOptions, oDataMedium)
	'Call GetPropertySample
	' Folder Selection
		Dim oFolder As String = ThisDoc.Path
		Dim Dialog = New FolderBrowserDialog()
		Dialog.SelectedPath = oFolder
		Dialog.ShowNewFolderButton = True
		Dialog.Description = "Select Or Create A Folder Where You want PDFs TO be Created"
		If DialogResult.OK = Dialog.ShowDialog() Then
			oFolder = Dialog.SelectedPath
		'MessageBox.Show(oFolder, "Title")
		End If
'    If Not System.IO.Directory.Exists(oFolder) Then
'        System.IO.Directory.CreateDirectory(oFolder)
'    End If
'    '- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -
    Dim oRefDoc As Document
    Dim oDrawDoc As DrawingDocument
	Dim oPenDoc As  Inventor.DrawingDocument
    For Each oRefDoc In oDoc.AllReferencedDocuments
        oBaseName = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName)
        oPathAndName = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName) & "\" & oBaseName
        If(System.IO.File.Exists(oPathAndName & ".dwg")) Then
            oDrawDoc = ThisApplication.Documents.Open(oPathAndName & ".dwg", True)
'NEED HELP HERE IN GETTING THE REV# FROM THE CUSTOM IPROPERTY OF THE DWG THAT IS OPEN IN ABOVE LINE
			oDataMedium.FileName = oFolder & "\" & oBaseName  & ".pdf"
           Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
            oDrawDoc.Close(True)
        Else
            oNoDwgString = oNoDwgString & vbLf & dwgPathName
        End If
    Next
'    '- - - - - - - - - - - - -xx - - - - - - - - - - - - - - - - - - - -
'    '- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
    oBaseName = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
    oPathAndName = System.IO.Path.GetDirectoryName(oDoc.FullFileName) & "\" & oBaseName
    If oDoc.DocumentType = kAssemblyDocumentObject Then
        oDrawDoc = ThisApplication.Documents.Open(oPathAndName & ".dwg", False)
        oDrawDoc.Close
    ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
        Call PDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
    End If
    MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
    'MsgBox("Files found without drawings: " & vbLf & oNoDwgString)
    Shell("explorer.exe " & oFolder,vbNormalFocus)
End Sub
Sub ConfigurePDFAddinSettings(ByRef PDFAddIn As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
    PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    oOptions.Value("All_Color_AS_Black") = 1
    oOptions.Value("Remove_Line_Weights") = 0
    oOptions.Value("Vector_Resolution") = 400
    oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
    oOptions.Value("Custom_Begin_Sheet") = 1
    oOptions.Value("Custom_End_Sheet") = 1
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
End Sub
@ nigel.hay @Curtis_W. @MechMachineMan
WCrihfield
Try a code like this to get the value of that custom iProperty for the drawing you are about to export as PDF:
oRevNum = oDrawDoc.PropertySets.Item("Inventor User Defined Properties").Item("REV #").Value
Beware though...if that custom iProperty does not exist in that document, this line will throw an error.  You can avoid that though by using a couple more lines of code to check if it exists, before trying to get its value.
I don't know if the data that you put as the Value of that iProperty is a String or Integer, but it would most likely be best to pre-define the Type of the variable 'oRevNum' (or whatever variable you want to use).  If it is a String value then:  Dim oRevNum As String...then you can check if it was empty or not by: If oRevNum = "", to avoid potential errors/issues.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
