How to access elements of .iam file in sheet view?
Henryk_Konczylo
Henryk_Konczylo
Is there a way to access underlined element, using iLogic?
What I want to do, is to count every underlined element, and then return somethink like this:
0002 -> 1
1001 -> 5
JhoelForshav
Hi @Henryk_Konczylo
How about something like this? 🙂
Run this rule in the drawing. The rule will prompt you to pick a view and then return a list as described by you 🙂
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Pick view")
If oView Is Nothing Then Exit Sub
Dim sumString As String = "Components in view " & oView.Name & ":" & vbCrLf
Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	For Each oRefDoc As Document In oDoc.AllReferencedDocuments
		Dim oCount As Integer = oDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc).Count
		If oCount > 0 Then
			sumString = sumString & vbCrLf & IO.Path.GetFileNameWithoutExtension(oRefDoc.DisplayName) & " -> " & oCount
	Next
Else
	MsgBox("view doesn't reference an assembly")
	Exit Sub
MessageBox.Show(sumString, "Occurrence count")
Henryk_Konczylo
Many thanks,
Your code helped me a lot 🙂
I changed it a little 🙂
Dim oSheets As Sheets = ThisDoc.Document.Sheets
Dim oSheet As Sheet
For Each oSheet In oSheets
	oView = oSheet.DrawingViews.Item(1).Name
	Dim sumString As String = ""
	Dim oDoc As Document = oSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
			If oCount > 0 Then
		Next
	Else
		Logger.Info("view doesn't reference an assembly")
	Logger.Info(sumString)
Next
