C# getting the sizes of component
nguyenduyanh82
Message 1 of 1
nguyenduyanh82
I'm writing an Add-in by C# with the method "SurfaceBody.OrientedMinimumRangeBox". My add-in have two methods to get the sizes: Global UCS and Custom UCS. My form have a "ComboBox" with 2 options: "Manual" and "Auto"  So I have a problem with "ClientGraphics". Below are code and picture:
   public partial class Form2 : Form
        private Inventor.Application _invApp;
        private Inventor.PartDocument _partDoc;
        private Transaction transac;
        public Form2()
            InitializeComponent();
        private void Form2_Load(object sender, EventArgs e)
            if (ConnectInventor())
                cmbMethod.SelectedIndex = 1;
                UpdateCustomiProperty("FThick", 0);
                UpdateCustomiProperty("FWidth", 0);
                UpdateCustomiProperty("FLength", 0);
        private void btnOK_Click(object sender, EventArgs e)
            Close();
        private void btnCancel_Click(object sender, EventArgs e)
            if(transac != null)
                transac.Abort();
                _invApp.ActiveView.Update();
            Close();
        private bool ConnectInventor()
            try
                try
                    //Get active Inventor object
                    _invApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") as Inventor.Application;
                catch (COMException)
                    MessageBox.Show("Inventor must be running.");
                    return false;
                //Make sure that at lease one document is opened
                _partDoc = _invApp.ActiveDocument as PartDocument;
                if (_partDoc == null)
                    MessageBox.Show("A assembly document must be active.");
                    return false;
            catch (Exception e)
                MessageBox.Show(e.Message);
                return false;
            return true;
        private void lblSwapA_Click(object sender, EventArgs e)
            string temp = txtFThick.Text;
            txtFThick.Text = txtFWidth.Text;
            txtFWidth.Text = temp;
        private void lblSwapB_Click(object sender, EventArgs e)
            string temp = txtFWidth.Text;
            txtFWidth.Text = txtFLength.Text;
            txtFLength.Text = temp;
        private void UpdateCustomiProperty(string PropertyName, double PropertyValue)
            // Get the custom property set
            PropertySet customPropSet = _partDoc.PropertySets["Inventor User Defined Properties"];
            // Get the existing property, if it exists
            Property prop = null;
            try
                prop = customPropSet[PropertyName];
            catch
                customPropSet.Add(PropertyValue, PropertyName);
        private void cmbMethod_SelectedIndexChanged(object sender, EventArgs e)
            TransientBRep transBRep = _invApp.TransientBRep;
            TransientGeometry transGeom = _invApp.TransientGeometry;
            double dir1, dir2, dir3, xLength, yLength, zLength;
            OrientedBox alignedRangeBox;
            UnitsOfMeasure uom = _partDoc.UnitsOfMeasure;
            if (cmbMethod.SelectedIndex == 0)
                txtFThick.Enabled = false;
                txtFWidth.Enabled = false;
                txtFLength.Enabled = false;
                // Combine all bodies in Part into a single transient Surface Body
                SurfaceBody combinedBodies = null;
                foreach (SurfaceBody surfBody in _partDoc.ComponentDefinition.SurfaceBodies)
                    if (combinedBodies == null)
                        combinedBodies = transBRep.Copy(surfBody);
                    else
                        transBRep.DoBoolean(combinedBodies, surfBody, BooleanTypeEnum.kBooleanTypeUnion);
                // Get the oriented minium range box of all boides in Part
                alignedRangeBox = combinedBodies.OrientedMinimumRangeBox;
            else
                txtFThick.Enabled = true;
                txtFWidth.Enabled = true;
                txtFLength.Enabled = true;
                SurfaceBody oBody = _partDoc.ComponentDefinition.SurfaceBodies[1];
                UserCoordinateSystem oUCS = _partDoc.ComponentDefinition.UserCoordinateSystems[1];
                // Create tranisent copy of body
                SurfaceBody transientBody = transBRep.Copy(oBody);
                // Get vectors aligned with UCS
                Vector ucsXAxis = WorkAxisToVector(oUCS.XAxis);
                Vector ucsYAxis = WorkAxisToVector(oUCS.YAxis);
                Vector ucsZAxis = WorkAxisToVector(oUCS.ZAxis);
                // Create transformation matrix from UCS to WCS
                Matrix UCSToWCSMatrix = oUCS.Transformation;
                UCSToWCSMatrix.SetToAlignCoordinateSystems(FromOrigin: oUCS.Origin.Point, FromXAxis: ucsXAxis, FromYAxis: ucsYAxis, FromZAxis: ucsZAxis, ToOrigin: transGeom.CreatePoint(), ToXAxis: transGeom.CreateVector(1, 0, 0), ToYAxis: transGeom.CreateVector(0, 1, 0), ToZAxis: transGeom.CreateVector(0, 0, 1));
                // Transform transientbody from UCS to WCS
                transBRep.Transform(transientBody, UCSToWCSMatrix);
                // Create transformation matrix from WCS to UCS
                Matrix WCSToUCSMatrix = UCSToWCSMatrix.Copy();
                WCSToUCSMatrix.Invert();
                // Transform corner point of rangebox from WCS to UCS
                Point cornerPoint = transientBody.RangeBox.MinPoint.Copy();
                cornerPoint.TransformBy(WCSToUCSMatrix);
                // Scale UCS vectors to match dimensions of rangebox
                ucsXAxis.ScaleBy(transientBody.RangeBox.MaxPoint.X - transientBody.RangeBox.MinPoint.X);
                ucsYAxis.ScaleBy(transientBody.RangeBox.MaxPoint.Y - transientBody.RangeBox.MinPoint.Y);
                ucsZAxis.ScaleBy(transientBody.RangeBox.MaxPoint.Z - transientBody.RangeBox.MinPoint.Z);
                alignedRangeBox = transGeom.CreateOrientedBox(CornerPoint: cornerPoint, DirectionOne: ucsXAxis, DirectionTwo: ucsYAxis, DirectionThree: ucsZAxis);
            // Get length of each side of mininum range box
            dir1 = alignedRangeBox.DirectionOne.Length;
            dir2 = alignedRangeBox.DirectionTwo.Length;
            dir3 = alignedRangeBox.DirectionThree.Length;
            // Convert lengths to docuemnt's units
            dir1 = uom.ConvertUnits(dir1, "cm", uom.LengthUnits);
            dir2 = uom.ConvertUnits(dir2, "cm", uom.LengthUnits);
            dir3 = uom.ConvertUnits(dir3, "cm", uom.LengthUnits);
            // Sort lengths form smallest to largest
            List<double> lengths = new List<double>();
            lengths.Add(dir1);
            lengths.Add(dir2);
            lengths.Add(dir3);
            lengths.Sort();
            xLength = lengths[2];
            yLength = lengths[1];
            zLength = lengths[0];
            //// Create surface to represent oriented range box...
            // Create starting box with dimensions of oriented rangebox.
            Box startBox = transGeom.CreateBox();
            Point boxMaxPoint = transGeom.CreatePoint(alignedRangeBox.DirectionOne.Length, alignedRangeBox.DirectionTwo.Length, alignedRangeBox.DirectionThree.Length);
            startBox.Extend(boxMaxPoint);
            // Create transformation matrix to move box to correct location/orienttation
            Matrix transMatrix = _invApp.TransientGeometry.CreateMatrix();
            transMatrix.SetCoordinateSystem(alignedRangeBox.CornerPoint, alignedRangeBox.DirectionOne.AsUnitVector().AsVector(), alignedRangeBox.DirectionTwo.AsUnitVector().AsVector(), alignedRangeBox.DirectionThree.AsUnitVector().AsVector());
            // Create surface body for the range box
            SurfaceBody minBoxSurface = _invApp.TransientBRep.CreateSolidBlock(startBox);
            // Transform range box surface body to the correct loction/orientation
            _invApp.TransientBRep.Transform(minBoxSurface, transMatrix);
            // Display range box on screen
            transac = _invApp.TransactionManager.StartTransaction((_Document)_partDoc, "DisplayRangeBox");
            ClientGraphics cGraphics = _partDoc.ComponentDefinition.ClientGraphicsCollection.Add("OrientedRangeBox");
            GraphicsNode surfacesNode = cGraphics.AddNode(1);
            surfacesNode.AddSurfaceGraphics(minBoxSurface);
            Asset targetAppearance;
            try
                targetAppearance = _partDoc.Assets["Clear - Blue"];
            catch
                Asset sourceAppearance = _invApp.AssetLibraries["314DE259-5443-4621-BFBD-1730C6CC9AE9"].AppearanceAssets["InvGen-001-1-2"];
                targetAppearance = sourceAppearance.CopyTo(_partDoc);
            surfacesNode.Appearance = targetAppearance;
            txtFThick.Text = zLength.ToString("#.#");
            txtFWidth.Text = yLength.ToString("#.#");
            txtFLength.Text = xLength.ToString("#.#");
        private Vector WorkAxisToVector(WorkAxis oWorkAxis)
            var p = oWorkAxis.Line.Direction;
            return _invApp.TransientGeometry.CreateVector(p.X, p.Y, p.Z);
Replies (0)
