How split body with sketch line
SandmanINV
SandmanINV
Hello everybody,
I have a body, and i want to split this body by lines in sketch like this.
I can extrude by surface then use split feature, but it take slower than if i can split body direct from sketch lines.
1. I read help that i need to create path before use split feature. But i don't know how, please help..
2. I created a sketch contain all of sketch lines which used to split body. But, i don't know how to run statement For...Each... loop. I practice with extrude command but not success. How should i do ?
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oline As SketchLine
Set oline = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(20, 0), oTG.CreatePoint2d(20, 1200))
Set oline = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(40, 0), oTG.CreatePoint2d(40, 1200))
Set oline = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(60, 0), oTG.CreatePoint2d(60, 1200))
For Each oline In oSketch.SketchLines
'Extrude
Set oprofile = oSketch.Profiles.AddForSurface
Set oextrude1 = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oprofile, 10, kSymmetricExtentDirection, kSurfaceOperation)
Next
Thank you,
dgreatice
Hi
I think Using sketchline it cant be process.
convert that line to work plane/worksurface
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
dakim930114
You can check the attached image for solution of your question.
The language is korean, you can understand with the red box location.
Thank you.
