iLogic InputBox, how avoid failure when cancel
BRLMCHKD
BRLMCHKD
Hi.
I would like help to solve my problem
rule / model error if I click 'cancel' in 'Enter value' prompt
The button is in itself inappropriate because I have already clicked 'yes'
in the 'Attention' prompt.
Attached my part, and screen cast showing my problem
Thanks /BRLMCHKD 🙂
By the way, going on 3 weeks holiday from this afternoon 🙂
Curtis_Waguespack
Hi @BRLMCHKD
Maybe something like this (see attached example  2017 part)
I hope this helps.
Curtis
iLogicVb.UpdateWhenDone = True
Answer = MessageBox.Show("Include machining?", "iLogic", _
MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'get the current parameter value
oCurrentValue = MachDiameter
'set variable to nothing as default
oMsg = ""
Set_Diameter:
If Answer = vbYes Then
	'set boolean
	Machined = True
	'show feature
	Feature.IsActive("Extrusion3") = Machined
	ThisApplication.ActiveView.Update()
	oDia = InputBox("Enter machining diameter" _
	& vbLf & "( Allowable diameter range: 0.65 to 0.95 )" _
	& vbLf & vbLf & oMsg, _
	"iLogic", oCurrentValue)
	If oDia = "" Then
		'handle null results of Cancel button
		Machined = False 'reset boolean
		Goto Set_Feature
	ElseIf IsNumeric(oDia) = False Then
		'handle non numeric value
		oMsg = "Value must be numeric" _
		& vbLf & "You entered: " & oDia
		Goto Set_Diameter
	ElseIf oDia < 0.65 Or oDia > 0.95 Then
		'handle zero or negative values
		oMsg = "Value not in range." _
		Goto Set_Diameter
	'set parameter to use input value
	MachDiameter = oDia
ElseIf Answer = vbNo Then
	Machined = False 'set boolean
	Goto Set_Feature
Set_Feature:
