How IV knows that a doc is from content center library?
my problem is as follows:
We have taken vaious parts from the content center library and modified them, for instance changed the material of a screw from steel to CNS and so on, and stored it as ipt with new name and part number and other changed iProperties in our workspace.
Inventor identifies our changed part still as content center library part.
So you see a special icon in the partslist windows (assemby and drawing).
Also Inventor lets you update the part from the content center, so a inattentive user could destroy our changes.
A call to the Application.ContentCenter.ContentCenterControlled(Document) function return false for our changed parts, so this is not the solution.
I know that parts form the content center have a special PropertySet called "Content Library Component Properties". The deletion of that whole PropertySet works fine with no errors. After that Inventor seems to loose the reference from that part to the content center library.
Is that the completely right way?
Are there still other references to the content center library in that part?
I have tested DocumentInterests and found no interests from content center addin.
I have also tested AttributeSets and also found no Attributes from content center.
What about PrivateStorage of a document?
Hello Autodesk guys, now it's your turn...
Guido
I have same problem as you.
I just save this part form content libary to my folders.  But if you replace it  in a assembly.  The location of  this part chang back to path of your content libary.  I have to find this part in the content libray and delete it.  Also I save this assembly file.
After that I reopen this assembly file.  Inventor does not find this part. So I find it in my folders.
That may solve this problem. But it have some trouble.  Anyone can have simple way to do?
Also I transfer the contern part as Stp, I open it  so that this part become as one part and not releate with libary.
But i also have the same problem.
