How do you retrieve a sketch symbol from a drawing
ATahaRYKKE
ATahaRYKKE
I'm having trouble finding how to delete a leftover sketch symbol (It's on the sheet) after replacing a titleblock. I tried searching the API manual, but I can't find how to select an object or how to determine the object type
Nevermind I figured it out
here is the code for those curious
  ' Deletes Logo Sketch Symbol
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
'Loop through sheets
For Each oSheet In oDrawDoc.Sheets
	'Loop through each symbol
	For Each oSymbol In oSheet.SketchedSymbols
		'look for the symbol by name
		If oSymbol.Name = "LOGO" Then
			oSymbol.Delete
		End If
	Next
Next
Curtis_Waguespack
Hi @ATahaRYKKE , I think you were very close,
edit: nevermind, I see that you figured it out
