How do you get the PointIntentEnum from an Assembly Joint?
JoeBarnes4076
Message 1 of 10
JoeBarnes4076
I am trying to make a copy of an assembly joint.  It appears that that the originone.IntentType and origintwo.IntentType do not return a PointIntentEnum which is required to properly recreate the joint.  Is this a bug or is there another way to get the PointIntentEnum?
Any help would be appriciated.
Replies (9)
Message 2 of 10
JaneFan
Hi @JoeBarnes4076 ,
It should return a value of PointIntentEnum. If it isn't, can I know what kind of value being returned in your side?
Select any joint from browser model, then run the following code in VBA environment.
Sub test()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oJoint As AssemblyJoint
Set oJoint = oDoc.SelectSet(1)
Dim oJointC As AssemblyJointDefinition
Set oJointC = oJoint.Definition.Copy()
Debug.Print oJointC.OriginOne.IntentType
End Sub
Jane Fan
Inventor/Fusion QA Engineer
Message 3 of 10
JoeBarnes4076
58117 for OriginOne
58118 for OriginTwo
Message 4 of 10
JaneFan
I see.
58117 is the value for IntentTypeEnum.kNoPointIntent and 58118 is the value for IntentTypeEnum.kPointIntent. KNoPointIntent is returned in the case of the GeometryIntent being created without Intent specified. If you want to switch the NoPointIntent to PointIntent, here is the way, in which kMidPointIntent can be values like kStartPointIntent, KEndPointIntent or else.
Sub test()
oJointC.OriginOne = oDoc.ComponentDefinition.CreateGeometryIntent(oJointC.OriginOne.Geometry, PointIntentEnum.kMidPointIntent)
End Sub
Jane Fan
Message 5 of 10
JoeBarnes4076
One of the main goals is to interrogate the existing Joint so it can be recreated with a new component instance using the previous Point Intent types.
I added the code
oJointC.OriginOne = oDoc.ComponentDefinition.CreateGeometryIntent(oJointC.OriginOne.Geometry, PointIntentEnum.kCenterPointIntent)
oJointC.OriginTwo = oDoc.ComponentDefinition.CreateGeometryIntent(oJointC.OriginTwo.Geometry, PointIntentEnum.kPlanarFaceCenterPointIntent)
Once the new joint is created the PointIntentEnum is lost and reverts to kNoPointIntent and kPointIntent.
Joe
Message 6 of 10
JaneFan
Hi @JoeBarnes4076 ,
I doubt whether it is something related to the geometry type. Is it possible to provide a simple model for reproducing it?
Jane Fan
Message 7 of 10
JoeBarnes4076
Here you go
Joints.iam is the assembly with two components
Message 8 of 10
JaneFan
Hi @JoeBarnes4076 ,
I see the thing here. Geometry for IntentOne is Circle Edge, but not circular face or Cylindrical face. In such case, KNoPointIntent is returned for IntentType. But it does no harm on creating the same new joint feature.
We don't need to switch it to KPointIntent on purpose if we want to create a same new one.
Sub test()
oJoint.Suppressed = True
Dim oNew As AssemblyJoint
Set oNew = oDoc.ComponentDefinition.Joints.Add(oJointC)
End Sub
Jane Fan
Message 9 of 10
JoeBarnes4076
I'm going to give up for now.  Thanks for your help.
Message 10 of 10
JoeBarnes4076
Ok, So I've tried this several ways and I can create Joints from scratch all day long using PointIntentEnum's in the CreateGeometryIntent method.
After the Joint is created from an AssemblyJointDefinition, it never returns what was used for the original PointIntentEnum's.
Is there some other method to determine what PointIntentEnum was used when the joint was originally created?
